Old 03-04-2002, 04:44 PM   #1
Gregwrx
Member#: 6753
Default engine stumble after mod?
Just installed the sti injectors & supra fuel pump. Car now hesitate's at part throttle between 4800rpm/5100rpm.does it at part throttle and full throttle. Engine cleans up and runs great above 5100rpm. Also did the ground mod at the same time. No cel's. Any hints? Thanks Greg
Gregwrx is offline   Reply With Quote
Old 03-04-2002, 07:57 PM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
use higher octane?
nhluhr is offline   Reply With Quote
Old 03-04-2002, 10:17 PM   #3
QA Guy
Member#: 6739
You might try disconnecting the newly added ground wires (to eliminate a variable) and see if the problem is still there.
QA Guy is offline   Reply With Quote
Weird on-boost stumble after Open ECU tune Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-16-2008 02:28 PM
Weird on-boost stumble after Open ECU tune Tronner Open Source Reflashes 0 10-08-2008 10:53 AM
Stumble at idle after mods 3XRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 03-28-2007 12:36 AM
Car stumbling after injector change Riles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-28-2006 12:55 PM
HELP....big problem with idle and stumbling after TGV removal and dual feed rails subiedave Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-11-2003 11:18 AM
