Old 07-02-2008, 07:13 AM   #1
ImpWagon
Member#: 181641
1995 impreza outback
red
Default a/t shifter does not light up
ok, i checked the mitchells, all-data @ work, and i even took the cover plate off. how do i get a new bulb or bulbs into the a/t gear selector so i can see what im doing at night. 95 imp. outback 2.2
ImpWagon is offline   Reply With Quote
Old 07-03-2008, 02:09 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
Im not 100 percent on this, but im pretty sure you remove the trim around the shifter, then remove the shifter itself, then you can pull the cover of where the gear selector is. There should be a pretty standard sized minibulb that can be found at an auto parts store in there.
ProdriveDreams is offline   Reply With Quote
Old 07-03-2008, 06:40 AM   #3
ImpWagon
Member#: 181641
red
thanks, if i get slow at work today ill rip it apart, post back and let you know if you were right.
Manny Lopez/Tesla loan does not add up AVANTI R5 Non-Subaru News & Rumors 14 06-29-2009 09:14 PM
a new kartboy shifter does not fit??? deuce106 Transmission (AT/MT) & Driveline 1 08-08-2008 04:57 PM
Help! Side markers and Parking lights not lighting up...? stevey323 Electrical & Lighting 1 03-25-2008 02:04 PM
Does it light up? berke996 Newbies & FAQs 2 02-06-2003 09:36 PM
De-fog switch..does it light up?? GooseMan Electrical & Lighting 18 12-30-2002 07:46 PM
Message Board Statistics All times are GMT -4. The time now is 11:58 PM.
