Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 07-02-2008, 11:39 AM   #1
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Default Fuel Line Help!
I'm just trying to find out the correct routing of these lines!!!
I finally have some time to finish up my swap after it sitting for months.
STi long block into 02 using perrin fuel lines. I believe this is all of the relevent info needed.
And wtf do I put this?!!?!?!?! I have a rotated set up now and if I remember right it was hooked up pre turbo, then again this was pulled apart nearly 2 years ago so I have no idea anymore haha.
domestic_abuser is offline   Reply With Quote
Old 07-02-2008, 06:47 PM   #2
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Green goes to your manifold to get a boost reading for the fuel pressure regulator.
Red is to link the manifold to the carbon canistor for emissions, it links to the "stuff" in the second picture that is supposed to be mounted to the front of the manifold on the passenger side.
You need to have a copy of the manual to set it up coreectly as there is also some electical connections involved as well.
I can send the relevant parts of the manual later tonight if you want.
WRX 2002 is offline   Reply With Quote
Old 07-02-2008, 11:44 PM   #3
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
What line is ran to the bov then?
Old 07-03-2008, 12:27 AM   #4
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
can anyone show me some close up pics of this area of their car with aftermarket fuel rails?!
Old 07-04-2008, 01:18 AM   #5
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
someone has to have a picture for me!
Old 07-04-2008, 01:46 AM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
If you post in the right forum you may get more help, this is "Built Motor Discussion" you want "Factory 2.5L Turbo Powertrain"
mick_the_ginge is offline   Reply With Quote
Old 07-04-2008, 06:51 AM   #7
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
well my car isn't a factory 2.5 car, and no I'm not trying to be a dick. I just find that in this forum there is usually more help than others. I do have part of the manual I need, it's just hard to interpret. I was just looking if another member had a picture from a tear down they might have done. Thanks for your help though!
Old 07-04-2008, 09:07 AM   #8
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
here is a pic I found of another members car. Correct me if I'm wrong, but the evap line runs my unknown "thingy" and back into the intake? Can I eliminate this and run my evap line straight to the intake manifold?
Old 07-04-2008, 02:25 PM   #9
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
I figured them out, thanks for the help everyone that provided it!
Pressure Fuel Line HELP! WolfDrive Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-22-2010 02:47 AM
Fuel line help or tool? akeric Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-20-2009 03:45 AM
2002 fuel line help ejpowerguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-01-2008 06:24 PM
quick fuel line help Lachlan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-04-2007 09:41 PM
FP SS Fuel feed line help!!! nuhga Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-17-2005 12:19 AM
