#1 |
Member#: 38829
NWIC
Vehicle:Not your usual 1997 Legacy GT |
Hey everyone... I've decided to add some zing to my motor while I'm replacing it with the lower mileage one (83k). I am shipping my cams off today to Delta Cam in Tacoma to have them do a stage 1/mild grind on them.
After I get them back I'll be adjusting the valve clearance to factory spec, having the heads tanked and checked out at the machine shop, resealing the motor with new seals all around and dropping it my GT. Anything else I should have done while it's out? I don't care to go into the bottom end at all. Supporting mods are Borla headers, Stromung HF cat pipe, custom catback with a Magnaflow muffler, Grimmspeed intake spacers, custom cold air intake, and most importantly, the throttle body bypass! ![]() I've also done all the suspension and drivetrain goodies, LW flywheel and pulley, poly bushes everywhere and dropped about an inch all around. I'll also be installing my new 06 WRX wheels with new rubber, a custom fiberglass sub setup, replacing the tired window tint, and a few other goodies for fun. I'm hoping to have around 200HP at the crank, but I won't know since I don't really plan on dynoing it real soon. It should be a lot more fun with the cams and a lower mileage motor though! My old motor had 200k hard miles on it when it died. I'll post the results of the autopsy later ![]() Aaron
#2 |
Member#: 4021
NESIC
Vehicle:1999 Legacy GT Ltd Quick Silver Metallic |
This is the Motor out of the '96 Legacy Outback that you are just getting through parting out ?
This was the first year of the EJ25, although I thought the EJ25 was only sold on the Automatic Outbacks, and the Outbacks with standard transmission stuck with the old tried and true EJ22. I think Patrick Olson did similar mods to his '97 Legacy GT, although he had Cobb redo his entire DOHC heads along with their cams (back when they were still working on the N/A EJ25), and he also got some Air Fuel mixture modifications (a pickbacked controller ?) so that the motor wouldn't run so rich at high engine RPMs. My memory was that he got ~112 BHP Wheel Horsepower on his dyno runs. |
#3 |
Member#: 36735
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
Aaron, sounds like fun!
#4 | ||
Member#: 38829
NWIC
I am going to run without EM for the immediate future, that was one reason I went with the mild cam grind as opposed to the more aggressive one. I figure I can always add something later, and since I don't know what my plans for the car are, I don't want to buy something now that won't meet my needs in the future. Hopefully I'll still have a lot of fun with the cams without a fuel controller. 112 WHP seems low, as these cars have 165CHP from the factory, and figuring roughly 30% loss, that would be about 115 WHP stock. If I did indeed add 35 ponies with exhaust and cams (is that too much?) at 30% it would be more like 140WHP. So either my loss numbers are too optimistic, or my power gain expectations are EXTREMELY optimistic! Pat, care to add anything? EDIT: I found Pat's dyno graph here, and the biggest differences are that he was running a piggyback A/FC with ported heads. Otherwise we've got pretty similar setups - stage 1 cams, full exhaust with UEL headers, intake, flywheel. But the AFC and ported heads probably make a decent difference - I was figuring 20-25 HP difference. That meshes well with my 140WHP expectation, I think. Pat, did you dyno before you did the ported heads and SAFC? Cheers, Aaron Last edited by fastenova; 07-03-2008 at 11:03 AM. |
#5 |
Member#: 32503
TXIC
Vehicle:2011 Tribeca 1995 Legacy Wagon |
The S-AFC can be had for like $125-150 on Fleabay and it's actually very easy to install. I would think it's worth it.
#6 |
Member#: 38829
NWIC
So besides the CELs I'm getting, and the very rough idle, this motor has really come alive! I am feeling awesome gains throughout the powerband, as Delta promised. It pulls all the way to redline, and has WAY more torque at highway speeds (60-80 MPH), in higher gears.
With four people in the car (~700 lbs) it feels like it used to with just me in the car (~200 lbs). When I'm alone, it flat hauls! The idle, when it's not running rough, sounds great. The motor definitely makes a bit more noise and sounds amazing. Under load this thing sounds like a bat out of hell! In fact, I might have to rework the exhaust to get it a little quieter ![]() It's a lot more fun to drive. Mileage so far is very poor but I attribute that to the intermittent misfires more than anything else. Once that goes away I should still be getting low to mid 20s and maybe upper 20s on the freeway. Aaron |
#7 |
Member#: 36735
Did you port the heads while they were out?
#8 |
Member#: 36735
#9 |
Member#: 38829
NWIC
#10 |
Member#: 184630
Vehicle:1999 Legacy SUS 2.5L green |
makes me wish i had money to rebuild my motor lol
#11 |
Member#: 82150
NESIC
Vehicle:1998 Legacy SL-i.net White |
The EJ25D stock whp is lower than 115. Maybe 95-105whp tops.
#12 |
Member#: 173080
Vehicle:1997 Legacy 2.0 GT Forest Green Metallic |
well thats just rediculous as the ej22 had 135bhp stock...
are yall sure thats right? |
#13 |
Member#: 82150
NESIC
That's at the crank. I'm talking wheel horse power. na EJ22 is AROUND 80whp.
#14 |
Member#: 173080
well that sucks..... I thought it was much better than that.....
#15 |
Member#: 82150
NESIC
Different type of dynos will give you close but different results. Also humidity, elevation etc are factors too. Check out the dyno thread on SLi to see what some people got. One member has 135 whp and he has a good amount of work done. If you plan on building a EJ22E you better wake up from that dream quick.
#16 |
Member#: 173080
is that the single port EJ22?
#17 |
Member#: 84568
NWIC
Vehicle:'98 540i 6M sport oxford/khaki |
Aaron once you get the misfires & stumbling idle figured out I need to go for a ride in it! Sounds like it hauls. Glade to hear its coming together.
#18 |
Member#: 184384
Vehicle:1999 Legacy 30th Ltd White |
Maybe I missed it? you have pics of the autopsy, I want to see.
#19 |
Member#: 38829
NWIC
#20 |
Member#: 184384
Ahh.. sorry, I assumed re-build. Good luck!
#21 | |
Member#: 38829
NWIC
I didn't get rid of the CEL but it's pretty quick! Hit me up sometime, we'll go for a ride. I also just got some JDM projectors in yesterday. =] Aaron |
| Thread Tools | |
| Display Modes | |
| FS: Go-Ped BigFoot, Motor scooter, fun, $300 OBO | PureTorque | Non-Subaru Stuff | 0 | 03-13-2008 10:49 PM |
| junkyard motor build (used parts budget build!!!) | shipjumper | Built Motor Discussion | 17 | 06-15-2006 06:35 AM |
| which motor build for fun street car... | 2000wrx | General Community | 5 | 04-20-2005 07:12 PM |
| Need Help with motor build!! | CUNNINGHAM | Factory 2.0L Turbo Powertrain | 2 | 07-14-2001 09:29 PM |
| ('93-'01) new motor build up | nico posteraro | Impreza Forum | 1 | 04-16-2001 08:37 PM |
