Old 07-02-2008, 05:54 PM   #1
idrum2loud
Member#: 182912
05 WRX
Default Weird noises when turning, popping noise HELP!
Ok so i just got an 05 wrx and i LOVE IT!
The car runs great and everything is great. One thing i have noticed recently is this. When i turn the car right, i hear a popping noise. Sometimes when i shut the car off, at the point where the engine shifts a little bit after you turn it off, i hear a rattle noise similar to the pop i hear when i turn right. Sometimes when driving slow over a lot of bumps and or dips in the street, i can hear the popping as well. The steering is tight, there are no suspension handling changes, and everything is fine at high speeds. I have been told it could be the spring not seating right, but i jacked up the passenger side of the car ( the side where the noise is) and everything seemed fine. Any help or ideas would be great! thanks guys!!!
idrum2loud is offline   Reply With Quote
Old 07-02-2008, 06:51 PM   #2
SlickRick51586
Member#: 66735
2004 WRX
could be your spring moving around (or not moving) the strut during turns, the steering rack, or the axle.
because you hear the noise when you turn the car off is odd.... would make me think its the axle....
i'm not an expert /shrug take it some place and have um take a look.
SlickRick51586 is offline   Reply With Quote
Old 07-02-2008, 07:00 PM   #3
LuckyNYC
Member#: 72812
2013 Impreza Sport
Ventian Red Pearl
Seems to be a very common problem (I'm find this out myself). I have the same issue. When I turn right I get the popping noise. I've given up and have had it in the shop for 3 days and they are thoroughly stumped so far. I don't get any noises when I shut off the engine though.
LuckyNYC is offline   Reply With Quote
Old 07-02-2008, 07:14 PM   #4
idrum2loud
Member#: 182912
05 WRX
I think its the vibration of the motor shaking like they do when there turned off that moves w/e it is just enough to make it rattle. I think its the Axle...cuz that would move with the motor since its all apart of the drivetrain etc. i would guess.
Old 07-02-2008, 09:44 PM   #5
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
idrum2loud - where are you located?
Fill out your profile.
RonJitsu is offline   Reply With Quote
Old 07-02-2008, 09:57 PM   #6
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
is the suspension stock? if not what aftermarket parts
UkNuck is offline   Reply With Quote
Old 07-02-2008, 10:02 PM   #7
idrum2loud
Member#: 182912
05 WRX
Yes the car is all stock.
Old 07-03-2008, 07:35 PM   #8
IMjustWRXed
Member#: 163254
02 EVO'd WRX 16g
284 whp / MD Mustang
i have the same exact prob...
seems like when turning really sharp,,, or when turning into inclined driveways ect.. that it makes this popping noise...
it also seems to have bad understeer,, much worse than my other wrx
i just got this 02 and my 03 never had these problems,,,
IMjustWRXed is offline   Reply With Quote
Old 07-03-2008, 07:57 PM   #9
seanvetter123
Member#: 174476
2002 Impreza RS
BRP
dunno if this helps but awhile back i had my front swaybar endlink break. and every time i turned i had a popping sound. and the only way to see it was when the suspension was compressed. when the shop put it on the lift to try to find the problem the suspension unloaded and you couldn't tell what was broken.
good luck figuring it out.
seanvetter123 is offline   Reply With Quote
Old 07-04-2008, 12:06 PM   #10
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
try driving in a circle (to the right) does this popping happen the whole time you are driving in that circle? if so, id bet 90% that its ur axle CV joint
pauli18c is offline   Reply With Quote
Old 07-04-2008, 12:07 PM   #11
idrum2loud
Member#: 182912
05 WRX
No it isn't a continuous pop....just happens when the car shifts in the direction it does when turning sharply right...and when the motor shakes on startup or shut down.
Old 07-04-2008, 12:17 PM   #12
pauli18c
Member#: 174553
2005 STi 360whp
the turning sharply makes me want to say perhaps a ball joint (lower?), but that shouldnt have to do with when the car is starting/shutting down... that sounds more like a motor mount issue.
if you jack it up, did u pull the tire side to side (9 and 3 oclock positions) and also vertically (12 and 6 oclock positions) and hear nothing? you should be able to hear and see if the ball joint is loose. try having a friend pull on the tire while you inspect all the joints
Old 07-06-2008, 03:58 PM   #13
idrum2loud
Member#: 182912
05 WRX
UPDATE!!!
Look at the difference in the sway bar end links....the crooked messed up looking on is on the passenger side..where the noise is coming from. Looks as if i need to replace that bad boy!
messed up side
Straight side
Old 07-07-2008, 12:42 AM   #14
pauli18c
Member#: 174553
2005 STi 360whp
i would recommend replacing both of those, it looks as if there is little or no grease at all left inside the rubber boots
popping noise when turning right jknakes Brakes, Steering & Suspension 1 07-12-2006 11:29 PM
Weird noise when turning Xtremeridher3 Transmission (AT/MT) & Driveline 3 05-10-2006 06:57 PM
Left front noise when turning hard right, help please! gtwagon941 Legacy Forum 21 01-10-2005 01:58 PM
JIC FLTA2 popping noise when turning wheel samwY Brakes, Steering & Suspension 1 05-27-2004 10:50 PM
flexing/popping noise when turning Moshpit552 Newbies & FAQs 1 11-06-2001 09:12 PM
