Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 06-30-2008, 10:09 PM   #1
Minjin
Member#: 163484
98 OB M/T
99 Miata
Default Interior lights - What should be lit? (98 OB)
Hi guys, I'm a new owner of a 98 OB Limited and I'm not sure what all should be illuminated on the dash and switches. I did a little bit of searching and it looks like I definitely need to replace the HVAC bulbs. What else do I need?
The only switch below the cluster that is lit is the cruise switch. I do have one green light in the window switches. Should anything else be lit up? Fog light probably? Defrost? How about switches on the center console? Also, does the low fuel warning light come on at start up?
If I need to replace a bunch of bulbs, does anyone know if they are fairly uniform across subarus? It would probably be much cheaper to get a box full of them at a u-pull-it junk yard than to get them from the dealer. Do these commonly go bad?
Thanks.
Minjin is offline   Reply With Quote
Old 06-30-2008, 10:25 PM   #2
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
hopefully you can tell what needs to be lit up. if you do a search you will be able to find a part number for the bulbs from radio shack
EDIT: check out this thread http://forums.nasioc.com/forums/show...highlight=hvac and follow the scoobymods page to get directions
legacy1907 is offline   Reply With Quote
Old 07-01-2008, 12:05 PM   #3
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Do your temperature selector and the fan mode buttons light up? Or is that just ambient light. (Legacy1907)
Frogsthatmoo is offline   Reply With Quote
Old 07-01-2008, 04:47 PM   #4
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
yes they light up
Old 07-01-2008, 04:47 PM   #5
Kansei
Member#: 173080
1997 Legacy 2.0 GT
Forest Green Metallic
It looks to me like they light up.... mine sure as hell dont...
Kansei is offline   Reply With Quote
Old 07-02-2008, 12:57 AM   #6
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Same here, I want mine to light up to. Which light bulb does the back lighting of the actual buttons?
Old 07-05-2008, 12:58 PM   #7
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Oh I want to do that, every night I bitch to myself why I can't see the AC controls or see which position to put the shifter in (Automagic here. lol)
kirbykirb is offline   Reply With Quote
Old 07-05-2008, 01:32 PM   #8
kirbykirb
Member#: 183596
2005 WRX/9-2x
http://www.scoobymods.com/forums/showthread.php?t=91
HAH this is how it's done. now to get time to actually do it.
Old 07-06-2008, 01:31 AM   #9
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
So the short bulb in this picture is the bulb that provides the backlight to the buttons and selector?
Old 07-06-2008, 09:18 AM   #10
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
could be, i cant remember, but to be safe i would just change eveery bulb so that you dont have to do it again anytime soon
Old 07-06-2008, 11:32 AM   #11
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
I used the same bulb for everything and it came out just fine. Use the Radio Shack Number, Radio Shack bulb #7219, catalog number 272-1092. They are like .25 a piece maybe.
You can also use this bulb on your buttons like the Rear defroster, Security, Cruise, Foglights. These should light up as well.
runninstrong is offline   Reply With Quote
Old 07-06-2008, 01:17 PM   #12
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Is it really that big of a pain in the ass?
Old 07-06-2008, 01:38 PM   #13
2.5GTLegacy
Member#: 111219
2005 SWP LGT
My god, all this time I thought it didn't light up
2.5GTLegacy is offline   Reply With Quote
What should be a healty 05 STI engine compression be? mspeed6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 05-31-2009 06:13 AM
Aftermarket wheels: What should be my cold tire pressure be? Wannascooby Tire & Wheel 13 06-06-2007 02:35 AM
(rant) Red light cameras should be attached to rocket launchers CosmoTheCat North West Impreza Club Forum -- NWIC 5 10-27-2005 10:38 PM
Engine getting opened...what should be done? Ru fan Normally Aspirated Powertrain 7 10-03-2001 06:04 PM
