Old 07-03-2008, 09:52 AM   #1
medrad_man
Member#: 142673
2006 STI
I've created a monster
Default Help! Hazards don't work but blinkers do
As the title says, my hazards don't work but my blinkers do. also the chime for my keys being in the ignition when the door is open is gone. Can anyone point me in the direction to correct this problem.
Dealership is out of the question since my car is heavily modified and the local dealer is the WORST in the state (seriously, it is).
I tried searching but couldn't find a definite answer, all i found was something about a relay of some sort but so info relating that to the key chime. Any help would be appreciated.
medrad_man is offline   Reply With Quote
Old 07-03-2008, 10:51 AM   #2
medrad_man
Member#: 142673
2006 STI
found that horn and hazards are linkind in fuse box. that fuse was blown, replaced said fuse and tried to honk horn...... nothing. Fuse is blown again. I put in a bigger fuse (20A), checked it to make sure it didn't blow immediately, tried honking horn, nothing and fuse is blown again.
Could this be the result of a bad relay or is the problem worse than that? Could this be caused by my 11.5lb braille battery (hazards and horn worked fine with the battery before)??
Old 07-03-2008, 11:11 AM   #3
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
Sounds like a short somewhere... never replace a fuse that keeps blowing with a larger one!
Is your car an 06STI? Take it to the dealership and let them fix it!
ptirmal is offline   Reply With Quote
Old 07-03-2008, 11:16 AM   #4
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
I 2nd both thoe statements, check the wiring, did you put in anything new recently?
skingfreak is offline   Reply With Quote
Old 07-03-2008, 11:27 AM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
check the relay
Old 07-03-2008, 01:15 PM   #6
medrad_man
Member#: 142673
2006 STI
Thanks for your input but apparently you didn't read my first post. The dealer near here sucks and will not touch most modded cars warranty or not and it doesn't help that i have an aftermarket battery. I could go to Austin but thats way out of my way.
I put in another new fuse and found that the hazards worked but when i pressed the horn it blew.
I removed the horn relay and hooked it straight to power to test it and it clicks. The socket for the relay has power where it is supposed to.
Could it still be the relay or would more likely be a short after the fuse box? Note that the only electrical mod i have done under the dash is running wiring for my gauges.
Old 07-03-2008, 03:56 PM   #7
ptirmal
Member#: 82243
07' Acura TL-S
I actually did read the whole thing but I have short term memory loss and forgot it when I was typing
Sounds like the short is in the horn wiring somewhere if that's what caused the fuse to go again. My money would be a short in the relay, relays go bad more often than other things.
BTW I don't think a dealership can pin the fuse blowing and deny service on any of your mods, a new battery is not a mod fwiw...
Old 07-03-2008, 04:26 PM   #8
medrad_man
Member#: 142673
2006 STI
gonna buy a new relay today
Hazards don't work NJHK Service & Maintenance 4 07-21-2009 12:28 AM
HELP! cd player working, but no sound coming out of the speakers ikkuy Car Audio, Video & Security 1 05-08-2006 11:00 AM
Sub does not work But Components Do? Hayaboosted Car Audio, Video & Security 9 09-08-2005 06:15 PM
Help! Brakes don't work! electricpork Brakes, Steering & Suspension 14 08-30-2004 04:22 PM
My low beams don't work, but my Highs do Bobalouy Service & Maintenance 2 01-20-2002 10:47 AM
Message Board Statistics All times are GMT -4. The time now is 07:37 AM.
