Old 03-04-2002, 09:25 PM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default Good way to check for exhaust leak
I'm sure alot of you have thought of this, but I remember reading alot of threads where people were looking for a way to find if there was a leak. I got in my car the other day and looked in the mirror and noticed the usual cold white exhaust smoke which is very visible right after startup during warmup. So the light bulb popped on in my head and I jumped on the ground to see tons of exhaust fumes shooting out from both ends of the midpipe and slamming into the ground. Probably pretty obvious, but might help some people out.
garface is offline   Reply With Quote
Old 03-04-2002, 09:30 PM   #2
Supapooh
Member#: 4461
02 2.slow
laser pointer in the dark works great too . I went out and bought one for 10 bucks or so. I had one....but it's attached to my s&w .40 Didnt think it'd be to smart waving that around.
Supapooh is offline   Reply With Quote
Old 03-05-2002, 10:16 AM   #3
BLZ2DWL:
Member#: 9919
1995 Legacy
I always just put my hand or a balled up rag over the tail pipe to block it. If the motor keeps running, chances are there is a leak somewhere. If you can try this and have somebody under the car, they are bound to hear where the exhaust is escaping, as it will now be the only place in the system where the exhaust can exit. I don't have a turbo though, so I don't know if this would apply since the blowoff valve might be the weakest link if you blocked the tail pipe off.
BLZ2DWL: is offline   Reply With Quote
Old 03-05-2002, 07:41 PM   #4
jlyttle
Member#: 2815
2004 Forester XT 5sp
Park the car while it is running, get in and close all the doors and windows. See if you start to get tired.
jlyttle is offline   Reply With Quote
Old 03-06-2002, 12:28 AM   #5
steppin16
Member#: 6010
i dont feel so good!!!
steppin16 is offline   Reply With Quote
Old 03-06-2002, 12:53 AM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
try taking a wet rag (really wet) & wrapping it around a connection & look for bubbles?
Tim Sanderson is offline   Reply With Quote
Old 03-06-2002, 01:34 AM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I use a stethescope. You can hear exhaust leaks around the headers/exhaust manifolds very good even if you could barely hear them with only your ear. They are also good for checking for vaccuum leaks.
Eric
Eric SS is offline   Reply With Quote
Old 03-06-2002, 10:14 AM   #8
ImprezedRS
Member#: 2771
2003 BMW Z4
I like the ideas of the stethscope but I don't have one so I use the good old fasion way of by the smoke on a cold morning start. But i might go pick up a stethscope since ylou can use them to listen to your motor to hear it making the weird noise you think you are hearing.
ImprezedRS is offline   Reply With Quote
best way to check intake manifold leak? marcus.raw Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 11-09-2007 07:27 PM
Best way to check for boost leaks Natoe Newbies & FAQs 3 06-30-2006 12:59 PM
Checking for exhaust leak? slyder626 Newbies & FAQs 5 03-16-2006 05:28 PM
Best way to check for BOV leak? txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-16-2004 11:41 PM
What's the best way to check for exhaust leaks? wgknestrick General Community 5 02-20-2003 10:33 PM
