Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 07-03-2008, 03:09 PM   #1
Member#: 132130
2002 Ford F-150
Graphite Gray
Default bank 1 o2 sensor under threshold - CEL
just last week or so my car keeps throwing a code for the front o2 sensor (bank 1) saying its below the threshhold or whatever..
im using an erz up pipe with the o2 sensor in it and a hks catless downpipe to oem wrx mid pipe to oem wrx axle back.
could it be a bad o2 sensor? part of me thinks it might be the car is running a little lean under 3K (td04 spoools quick ya know..) and thus possibly throwing the code?
keep in mind i have no piggybacks whatsoever installed anymore, and im using a blow-through maf. stock injectors.
mxpunk is offline   Reply With Quote
Old 07-08-2008, 04:00 PM   #2
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
My guess would be a bad O2 sensor - you could tell for sure by hooking up an OBD reader and monitoring the O2 sensor signal and see if the sensor is reacting properly.
jey is offline   Reply With Quote
FS/IA: Innovate LC-1 o2 sensor 2gnt2wrx MWSOC Private Classifieds 3 11-15-2009 10:17 PM
wtb bank 1 sensor 1 o2 sensor 03wrx05rscouple Tri-State Area Private Classifieds 1 08-03-2008 05:54 PM
replacement LM-1 O2 sensor.... SmoknWRX Engine Management & Tuning 3 12-19-2004 03:31 AM
Finally moved O2 sensor to prevent cel BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-04-2003 08:58 PM
Help, new O2 sensor and still CEL KimchiHo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-09-2002 01:25 PM
