Old 07-03-2008, 09:40 PM   #1
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Default CP Pistons or Wiseco Pistons???
I have both sets and trying to decide which set to use..
Plans for car:
2.5L STi short block - will have converted to closed deck.
Upgraded crank for oiling issues and rpms.
Built race heads - think 8500-9000rpm ish rev limit.
4094R Turbo 25-35psi of boost depending on whats next to me
07' N/A Intake Manifold - possable reverse mount.
Anyways looking to run 25psi most of the time but want to get it up to 35psi with out issue if possable. 35psi want be often but 30psi more then likly. Looking to make between 500-700whp depending on temps and boost.
Wiseco = 99.5mm bore, 9.0 cr, rist pin offset, 2618 alloy
CP pistons = 99.5mm bore, 8.2 cr, on center rist pin, 2618 alloy
Which ones would some of you use and why???
Thx for any input you have.
icslowmo is offline   Reply With Quote
Old 07-04-2008, 12:41 PM   #2
jazmak24
Member#: 171920
06 sti
aspen white
wiseco is the better of the two.
if you are trying to save money ,than go with th cp's
jazmak24 is offline   Reply With Quote
Old 07-04-2008, 01:00 PM   #3
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
I spoke to Clark Turner who explained that Mahle makes the best pistons for our engines.
Supposedly the wrist pin offset on other brands aren't correct for proper alignment on the block to remove the wrist pin if needed.
Honestly, just the fact that mahle has the longest track record for making pistsons for our motors is enough for me.
irascible is offline   Reply With Quote
Old 07-04-2008, 01:08 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by irascible View Post
I spoke to Clark Turner who explained that Mahle makes the best pistons for our engines...
Really? Now that is interesting...
flycaster is offline   Reply With Quote
Old 07-04-2008, 01:26 PM   #5
St.race
Member#: 136092
If I had to choose between Wisco and of the shelf CP, I would go with Wisco hands down.
St.race is offline   Reply With Quote
Old 07-04-2008, 02:05 PM   #6
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Seems to be Wiseco is the better of the two. Any reason why you all feel this way?? Reason why CP's not as good???
Old 07-04-2008, 05:56 PM   #7
my99maddog
Member#: 55515
1998 MY99
I was advised to use the STi gudgeon pins with Wiseco pistons. This was after an engine autopsy showed the (light) Wiseco pins had flexed under high boost.
my99maddog is offline   Reply With Quote
Old 07-04-2008, 06:02 PM   #8
kyleblix
Member#: 73495
Audi Q5, Ford Raptor
my tuner, (PDX) suggested mahle also....
kyleblix is offline   Reply With Quote
Old 07-04-2008, 06:19 PM   #9
bandit_2017
Member#: 131188
05 2.5 rst
i would go with the CP's because the lower cr
bandit_2017 is offline   Reply With Quote
Old 07-04-2008, 06:37 PM   #10
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
What piston pins are these??? Stock???
Old 07-04-2008, 07:43 PM   #11
flycaster
Member#: 60142
2011 WRX
Grey
Jeeeze...first Clark, now Jarrad? Since when did PDX go back to recommending Mahles? A year ago it was CP, period, after they had several Mahle 4032's break.
I assume this is the new 2618's, yes? And if you don't know, ask 'em if you don't mind. I'm curious.
Old 07-04-2008, 09:45 PM   #12
my99maddog
Member#: 55515
1998 MY99
May not be the same as Aus but standard WRX pins are fairly heavy. The STi items have a nice inside taper, retaining strength whilst losing some weight at the same time. Whilst the Wiseco concerned (pins only) were very very light! To try and describe the damage the piston had bitten the bore at both 90deg points from the axis of the Piston pins.
Old 07-04-2008, 09:59 PM   #13
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Wouldn't the closed deck have a tendency to overheat?
methaddict is offline   Reply With Quote
Old 07-04-2008, 10:08 PM   #14
flycaster
Member#: 60142
2011 WRX
Grey
...To try and describe the damage the piston had bitten the bore at both 90deg points from the axis of the Piston pins.
Are we talking gouges, or just bad scuffing. Also, what piston-wall clearance was used?
Old 07-05-2008, 08:32 AM   #15
my99maddog
Member#: 55515
1998 MY99
Very bad scuffing. Sorry, not sure on clearances.
Old 07-05-2008, 10:41 AM   #16
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
The piston pins that came with the Wisecos are not "light", they look to be 1/4inch think tubing, looks as good as stock USDM STi pins, I'll have to measure them.
The recommend clearance is 0.003 inch, mind you they also have the side skirt coating, so after that wears a little, that will open up a little.
Old 07-05-2008, 10:45 AM   #17
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
What is/was so good about the CP's, the 2618 alloy vs. 4032??? Is that really the only main difference between Mahle and CP???
Old 07-05-2008, 11:03 AM   #18
pddvl1
Member#: 134480
02 wrx
blue
Default posting up
The 2618 is the perfect piston, the 4032 gets brittle with high boost and can break so I have been told and read,these pistons are for non boosted engines, either cheap ass off the shelf piston will work fine just make sure and set the clearances to the manufacture spec and hope they dont fail. I would use cosworth pistons over your two choices but they cost twice as much, The mahle pistons are good too. You know Nascar and Formula one uses them they must be the best ?lol
pddvl1 is offline   Reply With Quote
Old 07-05-2008, 11:12 AM   #19
pddvl1
Member#: 134480
02 wrx
blue
Go to cgperformance.com these guys close deck blocks in sandrails in the desert and beat the crap out of them and they dont have any issues.
Old 07-05-2008, 11:16 AM   #20
pddvl1
Member#: 134480
02 wrx
blue
If you can't remove the piston with the wrong offset then how in the hell do you get them in? Have you pulled a Subaru piston out before ?
Old 07-05-2008, 11:19 AM   #21
pddvl1
Member#: 134480
02 wrx
blue
Default piston faq
The piston faq at the top of this forum should give you guys the just of all the piston materials and pros and cons of each
Old 07-05-2008, 01:09 PM   #22
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
What cgperformance shows is not a closed deck, it's just a brace the top of the cylinder which is very different. The lower cylinder still has a large coolant bath.
I have a fully closed deck block, I do not have a heat problem.
I like CP's, Wisco's & Mahle 2618's
mick_the_ginge is offline   Reply With Quote
Old 07-05-2008, 01:13 PM   #23
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Nice job on calling BS!!!!! I was thinking the same thing
Old 07-05-2008, 01:32 PM   #24
pddvl1
Member#: 134480
02 wrx
blue
The brace I think would be enough to support 30-35r power and keep the sleeves from moving back and forth and theprice is right 600-700 . I am really gun shy about sleeves and failure due to install and dropping and such. The block does not seem to have the proper thickness to support the sleeves too thin on the outer shell area. I know you have had luck but your build is way over the top for my budget. How's the car been running for you?
Old 07-05-2008, 03:18 PM   #25
kyleblix
Member#: 73495
yes the 2618's
WTB OR, PNW: STi EJ257 .020(100mm) over Wiseco pistons, or short block w/.020 pistons outback2.5HO Private 'Wanted' Classifieds 3 07-24-2009 02:56 PM
CP Pistons, Turbo XS, Eagle, Cobb, Wiseco Pistons Maximum Output Vendor 'General Sale' Forum 14 07-16-2009 07:19 PM
WTB 100mm CP or similiar pistons k_thaosta Private 'Wanted' Classifieds 1 10-26-2008 09:23 PM
Cosworth or Wiseco Pistons?? nomorem3 Built Motor Discussion 2 09-12-2006 10:06 PM
Do I have 04 Pistons or 05 Pistons? Mr. Quick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 07-05-2006 11:04 AM
