Old 07-04-2008, 01:13 AM   #1
scoobydrivin219
Member#: 66719
Default my car is dead...
ok, so my car just keeps dying. tested the battery, its good, tested the alternator, it's good. think it might be an electrical thing but not sure what. have a remote started and alarm on, have had them on for a while now, but not sure where it's running to so can't unplug it to see if that's the actual problem, never did this before. car will sit for a while then start right up and run fine, but eventually always dies again and is down for a WHILE. occasionally, stepping on the brakes makes the radio turn off then back on. the lights dim if I have the wipers on, no interior lights at all, can't run the ac cause the car will definitely die. I know it's electrical, just can't figure it the hell out. Any suggestions?
scoobydrivin219 is offline   Reply With Quote
Old 07-04-2008, 02:37 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
what did you do to check the battery?
what did you do to check the alternator?
I am almost positive this is a bad alternator problem. Or an extreme case of corrosion.
ProdriveDreams is offline   Reply With Quote
I think my car is dead, jim. ctwrxwagon General Community 2 01-08-2004 12:58 PM
My car is dead luvmyrs Tri-State Area Forum 21 11-11-2003 02:25 AM
Emergency my car is dead!!! josh woodall Electrical & Lighting 5 10-11-2003 08:12 AM
my car is dead wrx_in_efx Texas Impreza Club Forum -- TXIC 8 11-16-2001 10:45 AM
My car is dead! help jjimpreza North West Impreza Club Forum -- NWIC 10 11-07-2001 10:10 PM
Message Board Statistics All times are GMT -4. The time now is 07:47 PM.
