Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 07-04-2008, 01:35 AM   #1
A7X
Member#: 121001
2006 WRX
WR Blue Pearl
Default HELP car overheating after VF39 install
I finished my VF39 install earlier and just flashed my car with the accessport. I started it up and everything seems ok. I filled up the resevoir and the radiator with coolant but it slowly kept getting hotter. The coolant was a mix of 50% subaru coolant and 50% water. I just turned it off and I'm going to wait for it to cool down and see if it needs more coolant. What went wrong? I'm not losing any coolant under the car btw.
A7X is offline   Reply With Quote
Old 07-04-2008, 03:03 AM   #2
dlh1999
Member#: 105629
2006 300c SRT8
Did you bleed the system (ie. lines going to the turbo)? I believe you need to do so to eliminate air pockets in the lines. Could be wrong.
dlh1999 is offline   Reply With Quote
Old 07-04-2008, 03:13 AM   #3
Davenow
Member#: 23676
100% chance of air bubble. This is a common thing.
Old 07-04-2008, 04:01 AM   #4
A7X
Member#: 121001
2006 WRX
WR Blue Pearl
I think you're right. What I also forgot until a little while after I posted this was to squeeze the radiator tube to pump the coolant because after I did that and then let it sit, it needed a lot more. It seems to be ok now after about an hour of driving. I'll definitely check it out tomorrow as well.
Old 07-04-2008, 12:50 PM   #5
WRXislander
Member#: 50064
'02 WRX
MBP
It will go away, and when it does, it won't come back.
WRXislander is offline   Reply With Quote
Old 07-04-2008, 12:56 PM   #6
fmauriwrx
Member#: 154806
2011 SWP WRX
How are you likng the new found performance?
fmauriwrx is offline   Reply With Quote
Old 07-04-2008, 02:40 PM   #7
P.J.
Member#: 116369
2012 STi sedan
silver, Stage 2
I just did a vf43 install and I do not have heat issues, however I did spend about 20 min clearing air bubbles (squeezing the tubes) also I clamped the hoses to limit air bubbles during the install.
Make sure you keep your water levels toped and over fill the at the radiator cap (spill when closing) and it will go away given there is not a leak somewhere.
I have been running for 5 weeks now, no Problems what so ever. How do you like the power?
PJ
06 WRX (vf43) with everything else they make for my car
P.J. is offline   Reply With Quote
Old 07-04-2008, 02:45 PM   #8
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
burp the raidiotor hose coming off the radiator and turning towards the air box after opening the coolant cap at the bottom left of your TMIC. do this until bubbles stop coming up and put a towel around this area b/c it will splatter a little.
pearljam11 is offline   Reply With Quote
Old 07-04-2008, 03:08 PM   #9
A7X
Member#: 121001
2006 WRX
WR Blue Pearl
The power is great but I'm pretty sure there is boost leaking because I think it should be more powerful. I mean, I can feel the difference but it seems sometimes it pulls harder then other times, for the reason stated at the bottom of here:
http://forums.nasioc.com/forums/show....php?t=1550088
Old 07-04-2008, 03:54 PM   #10
jack klompus
Member#: 152885
2014 Malibu LTZ
get a protune dude. Cobbs map sucks.
jack klompus is offline   Reply With Quote
Old 07-04-2008, 03:55 PM   #11
A7X
Member#: 121001
2006 WRX
WR Blue Pearl
i will. I dont have that much money right now but my bday is on the 20th so we'll see what happens
Old 07-04-2008, 03:59 PM   #12
Prevent
Member#: 149114
open the radiator cap, turn the heat on high and let it idle for a bit. see what it does should bleed all the air out
Prevent is offline   Reply With Quote
Old 07-04-2008, 06:31 PM   #13
Foska Oats
Member#: 144081
2003 WRX
Are you still having the overheating issues.
Are there any other problems you are experiencing?
Foska Oats is offline   Reply With Quote
Old 07-05-2008, 08:22 AM   #14
A7X
Member#: 121001
2006 WRX
WR Blue Pearl
Nope, It's not overheating anymore as I stated above. The only other problem I'm having is at this thread:
Thanks for asking!
Overheating After Radiator Install?? Help! Electric Mayhem Service & Maintenance 4 02-21-2010 11:19 PM
wtf car overheating after header install...help plz SubieFan98 Normally Aspirated Powertrain 25 07-17-2008 06:09 PM
Need help ! Car stalling after FMIC install Javi_LGT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-30-2007 08:16 PM
Car overheated after Accessport install.... -Kevlar- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-21-2006 09:45 AM
Help!! Car Overheating after turbo install! bcristea Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-07-2004 01:04 PM
