Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 07-04-2008, 11:52 AM   #1
revenance
Member#: 121851
2003 wrx
YELLOW
Default Throltle Body Coolant Bypass
YAY or NAY???
i have my car completly apart and i was thinking of doing this. anything i should know about it? could it be bad in anyway?
any other quick bypass type mods i should do wile i have the intake man off?
thanks
revenance is offline   Reply With Quote
Old 07-04-2008, 11:55 AM   #2
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
Originally Posted by revenance View Post
YAY or NAY???
thanks
Not a bad thing, but I say its not worth it. Especially in a area that gets cold for 1/3 of the year.
JSarv is offline   Reply With Quote
Old 07-04-2008, 12:34 PM   #3
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Did it for the laughs. I didn't notice any difference.
rougeben83 is offline   Reply With Quote
Old 07-04-2008, 12:43 PM   #4
revenance
Member#: 121851
2003 wrx
YELLOW
did u just connect the 2 lines?
Old 07-04-2008, 12:44 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
I did it, but Im revered mani. So it saved having to run coolant lines to the tb. Its a good cheap mod though, no $ spent just remove one hose and loop the other hose to the nipple you removed the hose from. I dont think youll have problems if it is coll where you like, not like your tb is going to freeze up b/c there isnt hotass coolant going through it.
scby rex is offline   Reply With Quote
Old 07-04-2008, 01:19 PM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Yeah, just connect the two lines that originally connected to the TB together.
Old 07-04-2008, 02:10 PM   #7
big16gwrx
Member#: 129459
you shouldnt have any issues... mines been converted for a year or so now and no issues yet! i just re routed the one hose and used some vaccume caps from autozone to block off the other passages... it looks much more clean that way imho fyi i did mine when i did tgv deletes, p&p mani and the grimspeed thermal spacers
big16gwrx is offline   Reply With Quote
Old 07-04-2008, 02:18 PM   #8
revenance
Member#: 121851
2003 wrx
YELLOW
im also doing all those modds right now
Old 07-04-2008, 02:33 PM   #9
revenance
Member#: 121851
2003 wrx
YELLOW
anyone have a pic of different mothods of this?
also looking for pics of ways to re route the hard lines that went over the stock TMIC. not sure what they are call but most ppl put catch cans in there and what not. looking to reroute/hind them
Old 07-05-2008, 01:33 PM   #10
Ike83
Member#: 161681
2004 WRX
Definitely something I would recommend doing.
Ike83 is offline   Reply With Quote
Old 07-05-2008, 03:58 PM   #11
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
Ive been running mine for about a year and it does make a difference. Its not a big power adder but it helps keep the air going into the engine cooler. Ive read about people running this up in alaska and having no problems with thier TB getting tuck open due to the cold weather. Even if it is, let your engine warm up to normal operating temperature, engine temp > ice. It is very easy to do and super cheap, all you need is some hose, caps and a brass coupler fitting from homedepot or lowes ect.
In the picture you can see 2 red caps on either side of my TB where the coolant lines once flowed, all you do is disconnect the hose from the lower passenger side of the throttle body and insert brass coupler into the removed hose (I believe it ws a 3/8th fitting) now place cap over nipple that you just removed the hose from. Now go to the drivers side of the throttle body and remove the hose followed by plugging the nipple that it was removed from. Last step simply complete the circuit and connect the open ended hose to the other side of the brass coupler. Tuck away nice and clean...WALLA. Throttle body coolant mod, I think in all I spent under $5 and 5 minutes install time.
B00st3dWRX is offline   Reply With Quote
Old 07-05-2008, 04:08 PM   #12
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
In my picture you can see the lines running under the intercooler pipes and ontop of the block which replaces the pcv breather lines and connects to the turbo inlet all flowing to my cusco catch can, removing those 2 eyesore-ish soft and hard lines that ran on the tmic.
Old 07-05-2008, 04:21 PM   #13
parnous prepa
Member#: 183882
yeah, i am thinking to remove this when i am looking the throttle body
NB: sorry for my bad english i am French
parnous prepa is offline   Reply With Quote
Old 07-05-2008, 09:07 PM   #14
revenance
Member#: 121851
2003 wrx
YELLOW
what department of homedepot/loews did u find the red caps?
Old 07-05-2008, 11:58 PM   #15
JSarv
Member#: 163445
l33t *******
I think the theory behind it is heatsoak... I thought about it a bit today, and during an extremely hot idle coolant could actually cool the TB a bit.
This would only apply if temps at the TB were above 200*F...
Old 07-06-2008, 02:04 AM   #16
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I also did it, but didn't notice anything.
Old 07-06-2008, 02:13 AM   #17
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
the little caps were actually bought at pepboys in a variety pack, however they have them at home depot and hardware stores. You can prolly just print out that picture and say "where are these"
Old 07-06-2008, 02:31 AM   #18
revenance
Member#: 121851
2003 wrx
YELLOW
cool thanks,
im also looking for a good pic of the catch can setup and all those lines if anyone has a digram or some good pic it would help me out alot
thanks again
Old 07-06-2008, 02:39 AM   #19
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
I can take some tomorrow for you
Old 07-06-2008, 04:04 PM   #20
revenance
Member#: 121851
2003 wrx
YELLOW
awesome thanks
Old 07-13-2008, 12:27 AM   #21
revenance
Member#: 121851
2003 wrx
YELLOW
ever get pics?
Old 07-13-2008, 01:47 AM   #22
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
oh crap bro Im so sorry, totally blanked my wheels just got here so Ive been pre occupied.
Here ya go
So here is the T connecting the left and right banks:
Lines routed together under the throttle body:
Connecting to the other side:
into catch can:
back out and following the alternator leads:
clean side going back into the intake track:
sorry about the delay
Old 07-20-2008, 02:56 PM   #23
fabzilla
Member#: 132417
1999 Impreza GT WRC
hi!
it seems to be a nice mod, even if you don't see any difference! I think it's very interesting if you do this mod and add the phenolic intake gasket to reduce the air temperature ! then the knock should be reduced and you should keep your engine ok!
Fab
fabzilla is offline   Reply With Quote
Old 07-26-2008, 10:34 AM   #24
revenance
Member#: 121851
2003 wrx
YELLOW
what size lines/fittings are those??? 3/8???
Old 07-26-2008, 10:45 AM   #25
Tap
Member#: 21893
2002 WRX w/STi swap
I also use the bypass for my water temp gauge as coolant always flows through it.
Tap is offline   Reply With Quote
Throttle Coolant Bypass Mod NavyBlueSubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-15-2013 02:58 PM
throttle body/coolant bypass stage2?? Interior & Exterior Modification 12 07-20-2009 04:05 PM
06 wrx throttle body coolant bypass question I Love Boobies Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-23-2008 11:24 AM
Throttle body coolant bypass problem? SubasaurusWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2006 03:05 PM
Throttle body coolant bypass = blocking flow instead of rerouting? athakur999 General Community 7 04-13-2006 09:33 PM
