Old 07-04-2008, 03:05 PM   #1
kh15
Member#: 132400
Default how many gauges is to many?
right now i have a boost, wideband egt, and oil pressure gauge all wired up to the my clock with a 3amp fast acting fuse in line. i would like to add a water temp gauge and just wire it to the same place because its so quick and easy but i dont want to overload anything? is their any risk of damage as long as im using the correct fuse?
kh15 is offline   Reply With Quote
Old 07-05-2008, 10:18 AM   #2
03WRX_Rich
Member#: 64660
2003 WRX
Silver & Dirt
http://forums.nasioc.com/forums/show....php?t=1512114
I'm thinking this is an example of too many gauges.
Now, if you're talking about how many you can wire in parallel together, you still might be under the 3 amp limit. Check the draw on your gauge packaging.
03WRX_Rich is offline   Reply With Quote
Old 07-05-2008, 11:12 AM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
if you have enough mods to need gauges then you can fix it if it breaks. Having gauges doesn't make the car bulletproof. No do they give you any piece of mind.
I stand by my rule of 1 gauge. A boost gauge.
By the time anything else bad happens and you are able to notice it by watching your gauges other than the road infront of you the damage is already done.
I can't stand 8 million gauges in a car. It looks tacky and 99.9999% of people don't know what to do with them anyway.
sidewayz is offline   Reply With Quote
Old 07-06-2008, 03:45 PM   #4
kh15
Member#: 132400
well call me crazy but i like the comfort of knowing things like boost levels, a/f ratio's, and oil pressure!
new springs, how many miles is to many on stock struts? pittsburghscoobie Brakes, Steering & Suspension 7 01-08-2010 11:25 PM
How many miles is to many miles to buy a Used Exhaust? OBPStiInMyEye Newbies & FAQs 17 06-14-2008 09:47 AM
so how many miles is to much for a subaru omgIMaTOmato Newbies & FAQs 4 02-29-2008 03:52 PM
Looking to buy a GC/GF...how many miles is too many? arem Subaru Conversions 5 12-22-2007 03:09 PM
How many miles is to much? tubular031 Newbies & FAQs 7 06-11-2005 09:30 PM
