Old 07-04-2008, 07:08 PM   #1
03 spec r1
Member#: 183864
03 wrx spec r1
yellow
Exclamation weird HID problem
ok this is very diffucult to explain without showing.i just installed a GT hid kit (Bi-xenon) in my wrx and the hids themselves work fine, no flickering, go colour and transition to hi/lo beam. but i am having a weird problem with my fog lights! when i turn my fogs on with the car off the fogs will either do nothing, come on, or come on and switch to high beam, the button for the fogs can also control high beams??!!? (the high beam dash light comes on faintly when fog button is in).so now when i turn my car on, and the hids on i found that if i pushed the button slowly the fogs would turn on with the lo beams. BUT i rev the car and hids go to hi beam!!!! WTF. has anyone ever experienced this problem?
my car has an underdrive pulley but that cant be the problem can it?
also a friend of mine said to just re run the fogs through a seperate toggle switch.
any opinions or experience would be greatly appreciated!!
03 spec r1 is offline   Reply With Quote
Old 07-05-2008, 12:59 AM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
this is a common problem. it sounds like you have some grounding issues, and have some crossed up wires.
do you have knowledge of how subaru uses switched grounds in the 9007 plug? most people assume that the middle pin is ground and the 2 outer pins are positives for the respective high and low beams. this is wrong.
check out this wiring diagram. i made this for my fx35 projector retrofit, but its in essence the same type of set up as a dual capsule hid kit.
hope this helps.
the boxes with lines are relays, and you would substitute the solenoids for your high beam ballasts.
jdubya301 is offline   Reply With Quote
Old 02-09-2010, 09:09 PM   #3
quickstart
Member#: 218313
I just installed ddm tuning hi/lo for my 02 wrx. The high/low works perfectly, but now my fog lights dont turn on when I have the low beams on light they use to. Help??
quickstart is offline   Reply With Quote
Old 02-09-2010, 09:27 PM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
XanRules is offline   Reply With Quote
Old 09-19-2010, 11:44 PM   #5
bad300i6
Member#: 248757
I hooked up a set off hids off another car I had aftermarket units swapped the wires in the plugs to match the wrx's pinout and my foglights went out too. Is the foglight wired differently too
bad300i6 is offline   Reply With Quote
Very weird HID problem envyno1 Electrical & Lighting 1 10-07-2007 02:33 PM
weird HID!! Santo Domingo 2.5 RS Interior & Exterior Modification 4 12-14-2001 01:11 PM
Weird clutch problem when starting? LaxCat RS Normally Aspirated Powertrain 0 02-20-2001 05:33 PM
weird boost problems - fixed SteveS Technical Forum Archive 12 08-26-2000 12:22 PM
