Old 07-05-2008, 10:32 AM   #1
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
Default does 17" wheel make an impreza ride more quieter
02 impreza with stock springs , kyb gr2 shocks.... with 16" right now...
can a set of 17" with good tires make it ride more stable, and more quiet?
qualityracer is offline   Reply With Quote
Old 07-05-2008, 11:19 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
"more quieter"?
It mostly depends on the tire. Stiffer sidewalls can help with stability, but may create a harsher ride. Tread pattern/design makes the biggest difference in how quiet a tire is. You could probably gain both stability and quietness by just going to an upgraded 16" tire. Just do a lot of research before buying.
Old 07-06-2008, 03:19 AM   #3
subenerd
Member#: 72630
2004 STi
If you're worried about noise/comfort stick with 16's.
subenerd is offline   Reply With Quote
Old 07-06-2008, 10:55 AM   #4
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Generally the shorter the sidewall, the harsher the ride and the more noise you will hear. But this is also dependent on the tread design and sidewall stiffness. Sometimes worn tires can become quite noisy, so it may be possible to replace worn (and noisy) 16s with quieter (at least initially) 17s. But generally if you are concerned with ride and noise, stick with 16s. If you want more performance along with slightly more noise and a bit harsher ride, go with the 17s.
bcblues is offline   Reply With Quote
Old 07-06-2008, 11:29 AM   #5
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
Noise mostly depends on the tire. e.g. for summer season i have bridgestone potenza re050a and i can feel big difference when i put mine winter nokian wr tyres. Potenzo's are quite noisy tires...
Tomas26 is offline   Reply With Quote
Saab Aero 17" wheels on an '06 Wrx? Haven Tire & Wheel 17 12-19-2006 09:18 PM
Strong 17" wheels for an 04 sti? SLKWrx Tire & Wheel 6 02-21-2006 02:19 PM
17" wheels for Subaru Impreza, Legacy, Forester imprezzakc Private 'For Sale' Classifieds 8 01-24-2005 01:09 PM
FS: So. Cali Wrx Steering wheel make an offer awd_dreamin Private 'For Sale' Classifieds 14 03-22-2004 02:16 PM
What does 17" wheels improve? Heather Legacy Forum 32 05-03-2003 09:47 PM
