Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 07-05-2008, 09:07 PM   #1
lilrex89
Member#: 183700
2002 wrx
nighthawk black
Default swapping turbo
hey i'm gonna be swapping my stock turbo with a 16g, plan on putting bigger fuel pump and injectors, all that good stuff. already have front mount, tbe and up pipe. has anyone had any problems with a set up like this? and would i also need to swap out my fuel lines with a bigger gauge fuel line? just don't want to lean out the engine
lilrex89 is offline   Reply With Quote
Old 07-05-2008, 09:27 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Try checking with this guy, he seems to be doing the same sort of stuff and also doesn't know how to read the forum titles and figure out where to post. (Let me give you a hint: the "Built Motor Discussion forum" is for discussion of built motors. I know, it's wicked hard to follow, right? A turbo swap is not a built motor.)
engine swap turbo vs non-turbo deoderantX Subaru Conversions 2 03-18-2008 07:06 PM
Swapped turbo...same map that was 18psi is now 13-14psi Brian Broz Engine Management & Tuning 11 02-11-2004 11:11 AM
swap turbo withuot draining coolant??? TexRex2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-08-2003 11:31 PM
EJ257 shortblock swap + turbo onto a GME using the SOHC heads kgb Subaru Conversions 8 09-11-2003 12:51 AM
Need to make contact with the i-clubber who asked me about swapping turbos alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-14-2002 05:05 PM
