Old 07-05-2008, 08:30 PM   #1
n2oiroc
Member#: 141952
15 legacy 16 wrx
Default stock pistons rule!
finally tore down my stock block to part it out.
n2oiroc is offline   Reply With Quote
Old 07-05-2008, 08:37 PM   #2
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
I've seen some cracked ringlands but damn that is a chunk
wrxwagon253 is offline   Reply With Quote
Old 07-05-2008, 08:41 PM   #3
n2oiroc
Member#: 141952
15 legacy 16 wrx
when i first pulled it out it didnt look too bad except for the fact that the land between the 2nd and oil ring was also cracked. as soon as i pulled the rings off the pieces fell off and i started laughing! suprisingly, the cylinder wall is in great shape, no grooves or scratches!
Old 07-06-2008, 01:18 AM   #4
pddvl1
Member#: 134480
02 wrx
blue
Default awesome
nice job is that a cobb tune or what? I love a good broken ring land or two in the morning
pddvl1 is offline   Reply With Quote
Old 07-06-2008, 08:23 AM   #5
my99maddog
Member#: 55515
1998 MY99
I am pretty sure I am suffering the same symptoms, noisy on start up, #3 cylinder tests around 90, no noticeable power loss. How many km's did you do with it in this condition? Amazing the bore survived, how much boost caused that? Mine peaked around 1.45bar in 4th
my99maddog is offline   Reply With Quote
Old 07-07-2008, 03:13 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
My EJ22T pistons must be in better shape? 160k miles and 3k miles of hard driving with the EVO3-16G turbo. hummmm.....
FuJi K is offline   Reply With Quote
Old 07-08-2008, 12:35 PM   #7
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Looks a lot like my #4
06rexwagon is offline   Reply With Quote
Old 07-08-2008, 09:07 PM   #8
SaabTuner
Member#: 67608
Look at the way they broke off! In both cases it looks like some gas got between the two ring-lands and then went BANG!
The top appears to be torn up, the bottom, torn down. Highly unusual, but apparently, not uncommon with Subaru's, given that 06rexwagon seems to have suffered the same problem.
SaabTuner is offline   Reply With Quote
Old 07-08-2008, 09:48 PM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
stock ej22t piston
and my STI piston
Best stock pistons produced in USDM/JDM engines and Comparison to Aftermarket pistons Audioexcels Pre-2002 Factory Turbo Powertrain 13 03-01-2010 12:11 AM
ej22t piston rings for stock pistons gto7419 Pre-2002 Factory Turbo Powertrain 6 04-06-2009 09:29 PM
FS:VA: Sti short block, gaskets, Cobb 70mm intake, Sti stock pistons,stock bov trbowrx Engine/Power/Exhaust 14 08-23-2008 09:38 PM
Solo Stock strut rules, conversions, etc. JamesWilson Motorsports 2 12-21-2006 03:10 PM
Please clarify stock wheel rule solo2 del105 Motorsports 16 11-17-2004 06:23 PM
