Closed Thread
Old 07-05-2008, 09:55 PM   #1
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
Default Air Bag Light Stuck On!!
I searched this and was unable to find the information that I was looking for. My airbag light on my instrument cluster is stuck on. I can't figure why this is happening. I just turned my car on recently and the airbag light is now on. What could cause this and how can/may I be able to fix it? Thanks.
-Justin
xxxjuhstenxxx is offline
Old 07-05-2008, 10:42 PM   #2
MasterKwan
Member#: 98961
2003 WRX
It's broken and needs to be repaired. You probably need to take it to someone qualified so, an accidential deployment doesn't kill you.
They ought to be able to pull codes and figure out what's wrong.
MasterKwan is offline
Old 07-05-2008, 10:44 PM   #3
so steezy
Member#: 142506
07 WRX Limited
Wrong Fitment Crew #002
do you have seats with airbags?
so steezy is offline
Old 07-05-2008, 10:46 PM   #4
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
'04 WRX should have the side airbags in the seats (if my '03 has 'em, right?). I'd look around there to see if they haven't come unplugged or the wires cut.
djoye is offline
Old 07-05-2008, 10:49 PM   #5
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
Okay i have stock 04 seats. I will check and see if I can find a torn/unplugged wire.
Old 07-05-2008, 11:40 PM   #6
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
I checked the wires under the seats and they look fine, no damage at all. I plugged in my acessport and it didn't find any codes. Does anyone know what could be wrong?
Old 07-06-2008, 01:53 AM   #7
Weedy
Member#: 12340
2002 WRX 2.5L Hybrid
The SRS computer is completely seperate from the ECU. As already stated once, you need to have that looked at by a professional that is qualified. The SRS system is definitely not something to dork around with.
Weedy is offline
Old 07-06-2008, 03:58 AM   #8
Haelan
Member#: 151045
2013 Subaru STI
CBP
The airbag light tends to go off in my '04 as well. It only happens when the passenger seat is moved. Shaking the yellow-sheathed airbag wires under the seat corrects the issue. I'm not sure if the cable snagged at some point or if a wire broke from too much repetitive movement--they look physically fine as well.
It might be a good place to check. Anything more serious and I'd suggest a professional.
Haelan is offline
Old 07-06-2008, 06:55 AM   #9
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
yeh my airbag light always goes on..brought it to the dealler about 10bajillion times and its still coming on
jcbluescooby is offline
Old 07-06-2008, 09:06 AM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Find the yellow connectors under both front seats. Smoosh them together really tight 2-3 times. This will probably fix the problem. I do this 1-2 times a year when my airbag light comes on. I think the connectors have too much dielectric grease in them, but it's never annoyed me enough to find out the root cause.
Unabomber is offline
Old 07-06-2008, 01:15 PM   #11
xxxjuhstenxxx
Member#: 161666
2005 STI
CGM
Okay thanks for all the info, if the problem continues I will take it to subaru.
Old 07-06-2008, 01:31 PM   #12
burke25
Member#: 116748
2004 wrb wrx wagon
vf39'ed 280hp 262tq 6 spd
+1 for disconnecting the plugs under the seat and repluging them
burke25 is offline
Old 07-25-2008, 08:38 AM   #13
caslim
Member#: 42702
2004 Stroked Wgn Blk
GT 2.2L
It's crazy how many people have issues on the 04's with the Airbag light. Subaru needs to review the service reports from the dealers and assess how many people have brought their car in for this issue.
caslim is offline
Old 07-25-2008, 01:14 PM   #14
dru_hill
Member#: 67661
2004 WRX sedan
I had this too, and I drove around with it for like 4 weeks, constantly checking the plugs. Finally I got sick of it and took it to the dealer. They said when they turned the car on, the light was not on, and no codes came up with the reader, so they gave me the car back with no charge. That was like a year ago and it hasn't come on since. I think you need to take it to the dealer and then have nothing light up and look like a moron for it to be go away.
dru_hill is offline
Old 07-25-2008, 02:10 PM   #15
burke25
Member#: 116748
2004 wrb wrx wagon
mine just did it again like 2 days ago... this time it was the passenger plugs under the seats...you just have to unplug and replug
burke25 is offline
Old 01-28-2012, 12:22 PM   #16
nightmoves001
Member#: 218795
2004 WRX
RED
Nice.. quick fix mine to was the yellow wire harness under the seats also, a couple pushes in tight and that fixed the problem.
thanks again
nightmoves001 is offline
Closed Thread
HELP! 3.3 ohm resister installed and air bag light still on! RIP EP3 Interior & Exterior Modification 25 07-07-2007 12:20 PM
Air bag light come on after i disconnected it from the clock pod hornyturbo Electrical & Lighting 2 10-23-2006 07:46 PM
Air Bag light came on tonight :( SubaruImpreza_power Forester Forum 6 10-06-2005 04:28 PM
air bag light goes on, car gets unhappy. Keith Subaru Conversions 23 04-21-2005 12:41 PM
Air bag light is on Kranium31 Service & Maintenance 5 10-20-2003 06:50 PM
