Old 07-06-2008, 01:39 AM   #1
DUB03REX
Member#: 164939
02 Tacoma TRD
SV650 XR250 R6 Tiger 800
Default Please help an electrical n00b w/ wiring!
I am trying to wire my AccessPORT to a switch so I can leave it plugged in and turn it on and off as I please (since it is ALWAYS on when it is plugged in). Thread for reference: http://forums.cobbtuning.com/forums/...ad.php?t=34670
Here is my crude little diagram for reference. I have tapped into the power wire of the USB cable and wired it up to the switch.
2 questions:
a. Is this configuration gonna asplode something?
b. Where can I tap into a ground wire near by?
Thanks in advance for help.
DUB03REX is offline   Reply With Quote
Old 07-06-2008, 02:15 AM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Why are you grounding the power connection of the AP? That doesn't seem right to me. Don't connect anything to the third spot on the switch.
In other words thats "gonna asplode something"
Old 07-06-2008, 02:18 AM   #3
DUB03REX
Member#: 164939
02 Tacoma TRD
I just tested it out w/o grounding it, and the switched USB cable works.
The switch has a little red LED light on it. It didn't light up. I'm thinking that the ground on the switch is just so the light works?
Old 07-07-2008, 05:16 PM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
correct.
ProdriveDreams is offline   Reply With Quote
Old 07-08-2008, 10:52 PM   #5
DUB03REX
Member#: 164939
02 Tacoma TRD
Can anyone point me towards a known ground wire in the fog/cruise switch area I can tap into?
Old 07-09-2008, 12:16 AM   #6
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
All you need is a screw that is tied into the metal chassis of the car.
Old 07-09-2008, 12:40 AM   #7
DUB03REX
Member#: 164939
02 Tacoma TRD
Yeah, I realize I could run a long wire from the ground on the switch through the firewall and physically connect it to an existing ground point on the vehicle. I just figured it would be easier to vampire clip into an existing ground wire. I just don't know where one is, and I don't own a multimeter.
Old 07-09-2008, 12:32 PM   #8
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
a ground is basically any piece of metal that touches the chassis of the car.
really all you need to do is find a bolt that hits the frame, loosen it a bit, and wrap your ground wire clockwise around it, then tighten.
its best to use an actual crimp on connector, but its not 100% necessary for a ground
jdubya301 is offline   Reply With Quote
Please Help w/ TPS and FI Wiring Splice > EJ25 to EJ22 JT99 Subaru Conversions 6 10-14-2008 10:36 AM
PLEASE HELP ME! I need the wiring diagram for the dbw throttle system! snowcrzy Electrical & Lighting 4 08-11-2007 03:20 PM
Please help electrical n00b with Boost Gauge Install WRblueX_Guy Electrical & Lighting 15 06-10-2005 12:30 AM
Please help an idiot - Explain California energy 'deregulation' to me edkwon Off-Topic 16 12-18-2002 11:41 AM
Urgent, PLEASE HELP... I can't get speaker wire to doors! Skold Car Audio, Video & Security 8 08-24-2001 06:11 PM
