Old 07-06-2008, 01:06 AM   #1
turboedracer
Member#: 107617
2003 STi ej207
the silver bullet
Default Headlights
I know im going to catch S*** for this but can anyone send me a link for direction to put 04 STI headlights in to 04 WRX. looked in the HID FAQ didnt see a link for it or anything. Thank you
turboedracer is offline   Reply With Quote
Old 07-07-2008, 10:23 AM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Why would someone give you ***** for this?
I will be the first to commend you on NOT getting a PnP kit and putting it in the stock housing.
As far as your question goes, the housing (meaning outer shell) is identical between the WRX and STI with the exception that the STI has a ballast mounted to the bottom.
You will need to buy a wiring harness for these, as the startup current is more than the stock harness car handel (yes you CAN use the stock harness, but what is an extra $10-50?) anyway you will also need a 6pin leveler switch and harness for that (if you want the leveling function)
Any other Q's just ask
Jon
From a previous post i made.
if you need the schematic for the leveler system let me know i have it.
Switch ........ Headlight
Pin ................ Pin
SW0 - 7 ........ 1
SW1 - 6 ........ 2
SW2 - 3 ........ 3
SW3 - 4 ........ 4
+12V- 2 ........ 5 +12V
GND - 8 ........ 6 GND
skingfreak is offline   Reply With Quote
Standard Headlight to JDM (Non-HID) Headlight wrx2sti Interior & Exterior Modification 5 11-27-2002 01:38 PM
Help: Can't figure out how to install headlight bulb and harness back into headlight Gypsum2 Interior & Exterior Modification 2 07-29-2002 12:25 PM
steamed up headlights from doing headlight painting mod....help? aphex twin Interior & Exterior Modification 6 12-04-2001 10:43 AM
Are RS headlights the same as L headlights? slim speedy General Forum Archive 4 03-01-2001 12:42 AM
