Old 07-06-2008, 01:16 AM   #1
Pssshhhhh!
Member#: 125871
Default How to pull fenders???
I've seen people use fender rollers, hammers, and bats to "roll" fenders, but what/how exactly do you "pull" a rear fender? What tools do you use or how do you do it?
Pssshhhhh! is offline   Reply With Quote
Old 07-06-2008, 10:57 AM   #2
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
You can roll the rear fender the same as you do the fronts. If you are talking about flaring your fenders, that is best left to a reputable body shop.
bcblues is offline   Reply With Quote
Old 07-06-2008, 01:33 PM   #3
Silver'04
Member#: 116904
'04 Wagon
I think the OP is referring to pulling the rear fenders. I'm assuming rolling and pulling are 2 different things. I would also like to know the difference. I hear/see the term used a lot recently with the whole aggressive fitment movement. Any of you Norcal guys want to step in a enlighten us as to what exactly is a fender pull and how do you do it?
Silver'04 is offline   Reply With Quote
Old 07-06-2008, 03:57 PM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
A roll is when you make the lip flat. A pull is using the same tool and going beyond just flattening the lip..depending on how aggressive the pull is it often leaves a slight flare..
IMO a simple roll can be done with any tool, but a pull MUST be done with the proper fender roller tool.
Old 07-07-2008, 10:51 AM   #5
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
it also depends on what year your car is.
if it is an 05+ STi you're going to be hard pressed to use a fender roller in the rear.
How To: Properly Modify 05+ GD STi Rear Fenders
will give you a little how to on properly modifying the rear fenders, if you wanted more of a "Pull" you would just hammer it further.
for an 04 or a GDA,GRB,GC do the fender roller.
WRX8XB is offline   Reply With Quote
Old 07-07-2008, 11:04 PM   #6
Pssshhhhh!
Member#: 125871
So I know the fender can be rolled without damaging the paint, but can you also pull/flare the rear quarters without damaging the paint? Just curious.
Old 07-07-2008, 11:38 PM   #7
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
yes just use lots of heat
ray101381 is offline   Reply With Quote
Old 07-08-2008, 08:58 AM   #8
WRX8XB
Member#: 45323
and don't burn the paint.
Old 07-09-2008, 01:03 AM   #9
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
Youtube- "JDM Fender roll"
AWDBoost is offline   Reply With Quote
Old 07-09-2008, 01:28 AM   #10
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
that was so ghetto!
B00st3dWRX is offline   Reply With Quote
Old 07-09-2008, 01:53 AM   #11
2.5wagonkid
Member#: 178003
94 old leggy BC
panda
^^ true dat, i do that in a few years
2.5wagonkid is offline   Reply With Quote
Old 08-09-2008, 04:21 AM   #12
Jaylyons1
Member#: 113884
1989 Skyline GT-R
wow... heh, at least it worked for him! I'd **** somethin up if I tried that... lol
Jaylyons1 is offline   Reply With Quote
How to pull your oil pan without pulling the motor ihadmail Service & Maintenance 42 05-23-2015 02:27 PM
What is the widest wheel with lowest offset I can fit without having to pull fenders? subierider Tire & Wheel 0 04-12-2009 07:09 AM
How to pull your fenders? SLO_02WRX Interior & Exterior Modification 1 06-26-2008 10:27 AM
how to pull the grill? sybir Legacy Forum 8 04-11-2001 12:40 AM
how to pull diagnostic codes from ecu? tluzziracing Normally Aspirated Powertrain 7 11-10-2000 08:51 PM
