Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-05-2002, 09:40 AM   #1
MissDanz
Member#: 8400
2013 335i - Charlize
1991 318i - Greta
Angry Is there a such thing as touch up paint looking good?
Well, my baby has her first scars from some meanie in a parking lot, and I am angry! I think some of Orion's 'scratch remover' will help quite a bit, but there are still a few good sized nicks that I would like to try and smooth over. If I were to buy touch up paint, would it be:
a. too expensive
b. worth it
3. look any better than it does now
Just wanting a little advice because I know all of you boys are so smart!
Thanks for any info, and if anyone on here is actually good at applying touch up paint, I would appreciate the help!
cat
MissDanz is offline   Reply With Quote
Old 03-05-2002, 09:46 AM   #2
ExchangeGuy
Member#: 4383
2012 Camaro RS
Blsck/gray
Default Re: Is there a such thing as touch up paint looking good?
a. too expensive
b. worth it
cat
Touch-up never matches the original paint due to the clear coat applied to the original paint. So the touch up will alway look a little off from the original paint if looked at up close. You will know, everyone else will probably won't care to much....unless it is a judge..
Even an area repair will never match the original in some cases.
To make it even close apply a light dab on the area affected. let dry. Wait a while(next wash) and wax over it. It will be fairly close.
BTW...touch-up does NOT contain clear...it is just a base...
ExchangeGuy is offline   Reply With Quote
Old 03-05-2002, 09:47 AM   #3
Bankheist
Member#: 2237
2000 GC8 STi
2015 Ford Mustang GT
Bankheist is offline   Reply With Quote
Old 03-05-2002, 09:49 AM   #4
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
i'm getting a new Meguiar's product that i think will help us out.
Orion is offline   Reply With Quote
Old 03-05-2002, 09:49 AM   #5
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
Originally posted by Bankheist
www.lanka.com
so do they develop touch-up paint software or something?
Big_Hitter is online now   Reply With Quote
Old 03-05-2002, 09:50 AM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Cat,
here's the deal with touch up paint......it really depends on the scratch. Like i mentioned earlier.......if you can run your fingernail over the scracth and it catches it will probably not dissapear totally with polishing compound, but polishing compound may help it.
As for touch up paint.....if you can get it matched perfectly....which almost never happens....it's always a hair off.....and you can apply it only to the fine little line.....again which isn't always the easiest with the supplied brush.....if you can get some touch up paint that matches good, try and buff the scratch out first, and then get a small paint brush and be very meticulate about the paint it would probably help fix it up.
Then I'd apply some buffing compound over the scracth and use a cleaner wax on top of that to help blend it in with the rest of the paint.
Hope that helps...
Josh
Legacy777 is offline   Reply With Quote
Old 03-05-2002, 09:51 AM   #7
ExchangeGuy
Member#: 4383
2012 Camaro RS
Blsck/gray
www.lanka.com
What the hell does that have to do with this?
Old 03-05-2002, 09:52 AM   #8
Bankheist
Member#: 2237
2000 GC8 STi
try again
Old 03-05-2002, 09:53 AM   #9
ExchangeGuy
Member#: 4383
2012 Camaro RS
Blsck/gray
ahhh...much better....
Old 03-05-2002, 09:55 AM   #10
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
the Meguiar's thing works the same way.
Old 03-05-2002, 09:55 AM   #11
Bankheist
Member#: 2237
2000 GC8 STi
sorry, i went to the site, and said w t f? and then added a "g" it was all better.
Old 03-05-2002, 10:09 AM   #12
p7r4e7y
Member#: 4261
2000 2.5 RSTI
www.ModernImage.net
a. too expensive
b. worth it
a b 3, what happened to c?
p7r4e7y is offline   Reply With Quote
Old 03-05-2002, 10:11 AM   #13
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
Default Re: Re: Is there a such thing as touch up paint looking good?
it's too early for her. not enough coffee yet!
Old 03-05-2002, 10:12 AM   #14
Legacy777
Member#: 4800
Anyone actually tried the langka stuff?
A buddy of mine tried those crayon type fillers......they certainly don't work as well as they show on tv......
Old 03-05-2002, 10:15 AM   #15
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
it appears to be just a simple polishing compoud that evens the edges that the touch-up makes.
Old 03-05-2002, 10:54 AM   #16
MissDanz
Member#: 8400
1991 318i - Greta
Nope, I actually meant to put that, I was trying to add a little humor to a more or less depressing thread about my car, which I know, is not a Subaru and should not be spoken about on these forums...
cat
PS - Orion, I can now feel your pain! You have to let me in on whatever you have that might make my car almost perfect again!
Old 03-05-2002, 11:00 AM   #17
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
Default Re: Re: Re: Is there a such thing as touch up paint looking good?
cat
i don't think your pain is on the order of $500!!!
Old 03-05-2002, 11:01 AM   #18
ExchangeGuy
Member#: 4383
2012 Camaro RS
Blsck/gray
Default Re: Re: Re: Re: Is there a such thing as touch up paint looking good?
Ouch!! That was a nasty hit..!!
Old 03-05-2002, 11:42 AM   #19
MissDanz
Member#: 8400
1991 318i - Greta
Unhappy Orion
My pain may not be as financially devastating as yours, but emotionally, it equals, if not surpasses your experience! I have not had my car near as long as you have, and this being my first major ding problem, on my first ever brand new car, I am extremely crushed! I have lost all faith in common decency.
cat
Old 03-05-2002, 11:43 AM   #20
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
Default Re: Orion
cat
welcome to the darkside!
Old 03-05-2002, 11:47 AM   #21
MissDanz
Member#: 8400
1991 318i - Greta
Talking
Does that mean I am going to have to start listening to Night Ranger? If so, then I am done for!
cat
Old 03-05-2002, 11:50 AM   #22
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
cat
Hey I actually am still in shock over seeing that video last night!!!
It was the WORST video I've ever seen!
I was on KaZaA and AudioGalaxy till midnight!!!
Didn't anyone tell you you're supposed to respect your elders?
Old 03-05-2002, 11:53 AM   #23
MissDanz
Member#: 8400
1991 318i - Greta
Talking
Sorry, Pappy.
cat
Old 03-05-2002, 01:37 PM   #24
kaboom
Member#: 6160
2009 Legacy
Gray
my baby has her scars too, but i tell tell her its good for her personality and perdsonality goes a long way
kaboom is offline   Reply With Quote
Old 03-05-2002, 01:40 PM   #25
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
But your worst one is your fault, bush boy...
DanzBorin is offline   Reply With Quote
Is there really such thing as a breaking point for an exhaust?!?!?!?! pjloyd Newbies & FAQs 7 05-24-2010 03:09 AM
Is there a such thing as a roof rack delete? digitalmethods Interior & Exterior Modification 12 11-05-2007 10:58 AM
OT: Is there a such thing as a Firearms Blue book? LoriAngel Texas Impreza Club Forum -- TXIC 7 01-09-2006 12:02 PM
Theres no such thing as eternal justice... LotusDriftx Political Playground 5 01-08-2005 09:01 AM
Local Dealer Says Theres No Such Thing As A Paint Problems RAYS REX Warranty Issues & SOA Problems 28 08-14-2002 09:35 AM
