Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 07-06-2008, 09:34 PM   #1
C_Wood
Member#: 102234
05 Forester XT
Default Number 2 on my heat and AC won't work
Well I have done some looking around for about an hour now and haven't really found any solid threads on this.
My A/C and heat work fine on 1, 3, and 4 but when I put it on 2 it just dies. Put it back to 1, 3, or 4 and it still works fine. I took off the glove box and did some looking around for the blower motor speed resistor (since the other threads I found said to do so). Am I heading in the right direction with this? Anyone else have this issue?
This is what I found so far.
http://forums.nasioc.com/forums/show...Blower+Problem
Oh and this is in a 03 WRX
Thanks
-Charlie
C_Wood is offline   Reply With Quote
Old 07-07-2008, 11:59 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The problem is either the with the resistor for speed 2 (most likely), the switch position, or the wiring in between for that position. By following the wires back from the motor you should be able to find the resistors.
Old 07-07-2008, 05:14 PM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
EDIT: oops! my bad (see correct info below)
ProdriveDreams is offline   Reply With Quote
Old 07-07-2008, 05:28 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Actually the resistor assembly is located in the blower housing down under the dash, this is to keep the resistors in the airstream for cooling since they get hot. If you pull back the mats and carpet up front on the passenger side you will see two connectors going to the bottom of the HVAC housing, one is for the fan motor and the other is for the resistor assy. If you unplug the resistor connector and remove it (two screws), you can inspect it visually and test it with an ohmeter.
Old 07-07-2008, 10:45 PM   #5
C_Wood
Member#: 102234
05 Forester XT
Thanks for all the help guys. I found the resistor assembly and it has a nice burn mark in it. Time for a new one I guess. Thanks again.
-Charlie
Old 07-10-2008, 10:50 PM   #6
C_Wood
Member#: 102234
05 Forester XT
Well I swapped out the resistor assembly and guess what. Still no power on setting 2. I guess the switch is what I'm going to replace next... Only bad thing is I'm going on vacation for a week and won't be able to play with it.
Old 07-10-2008, 11:49 PM   #7
Cougar4
Member#: 53443
Winestone
You stated that the resistor assembly had a burn mark. Did you make sure all the connections to the resistor pack have a good connection to it?
Old 07-11-2008, 12:13 AM   #8
C_Wood
Member#: 102234
05 Forester XT
Well I thought it was a burn mark but I guess I was wrong. The new resistor assembly had the same mark so I'm guessing it was just where it was soldered. It didn't look to clean and looked dark, thats why I thought it was a burn mark.
Yep, I did make sure the connection to the resistor pack had a good connection.
Did STI TMIC and Hood swap on my wagon - Now hood won't latch? barryj Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-08-2008 10:17 PM
help please, ac won't work 97lgt illegal2.2 Legacy Forum 10 06-04-2008 11:53 PM
Going to MY97-01 Heating and AC? JJ's Red Wagon Subaru Conversions 0 08-07-2007 02:53 PM
problems with heat and AC MYnewWRX Service & Maintenance 1 12-02-2006 02:31 PM
my Tranny handles way differently when I have my heat, and other stuff on... lionken07 Transmission (AT/MT) & Driveline 4 11-11-2004 05:28 PM
