Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 07-07-2008, 11:50 AM   #1
AMR
NASIOC Manufacturer
Vendor Sales Rating: (1)
Member#: 171509
Default AMR SALE-Aquamist-Turbo XS-AEM-Injectors, TMIC, T50R Turbo, Shortblocks, Gauges, Meth
Methanol / Alcohol Injection Kits
AEM Water / Alcohol Injection Kit
The AEM Water Injection Kit is a cost effective and user-friendly alternative to very expensive water injection kits. The AEM Water Injection kit is a perfect way to reduce air inlet temps and increase charge density in boosted vehicles. This AEM kit allows the user to safely run higher boost pressures and suppress detonation allowing the utilization of more timing and boost. AEM's progressively controlled high-pressure pump draws water (or up to a 50% alcohol mixture) from the one gallon tank with integral fluid level sensor to provide boost-dependant variable flow. Your water is fed into the intake system via interchangable nozzles for additional flow control. An integrated system status light mounts on your dash will keep you informed with easily identifiable error codes that include short circuit warnings, battery voltage problems, and low fluid alarms. AEM aslo incorporated a failsafe that provides output to either decrease timing, or reduce boost if the system runs out of fluid or detects any error.
Complete kit includes:
-One gallon tank with integral fluid level sensor.
-Progressive control 150 PSI pump.
-Three different size jets.
-Dash mountable warning light.
-All hardware & hoses for insallation.
Aquamist HFS-5 Injection Kit
GETTING TO KNOW THE AQUAMIST HFS-5
Over the last few years, demand for great engine power output is increasing. Cubic inches option is no longer the norm. Squeezing out 200-300hp per litre is within the reach of the ordinary folks on the street. The tuning industry has grown to embrace new tuning technique as well as readily affordable
components to produce powerful and reliable engines.
Aquamist has also coming to terms with the inevitable, meeting the demands of the market and offering new systems capable of supporting engine power output up to 1000+ BHP.
The HFS-5 reads the duty cycle of a fuel injector and delivers water proportional to fuel flow. Water quantity is metered by a High speed inline valve and flow is monitored by a turbine flow sensor.
For clogged jet and severed hose. A number of options are available for the user to limit engine power in the absence of water flow.
We believe the HFS-5 meets all the requirement of a high-end water injection system for achieving fast engine transient and responses with absolute precision. Tracking the fuel delivery is the most reliable method to deliver your fluid flow under the whole engine operating cycle. Anything short of
this means having to tailor your fuel map to compensate the irregular fluid quantity ingested by the engine.
AEM Guages
AEM Tru-Boost Boost Controller
The AEM Tru-Boost Boost Gauge/Controller combination is a mult-featured system for simplified, comprehensive boost control. Packaged within a 52mm gauge are a 29psi capable boost controller, peak-memory boost gauge. Other features include overboost alarm and overboost shutdown, wastegate delay for faster spool up, and a driver for an external warning lamp.
NOTE: This unit includes black and silver bezels and black and white faceplates for simple color selection and easy matching to other AEM gauges (i.e. serial gauge, UEGO, etc.)
Features:
-52mm (2 1/16") Complete stand-alone boost controller gauge
-On-board pressure sensor included for boost levels up to 29 PSI
-Two user selectable units
-Peak boost memory
-User selectable over boost alarm with overboost shutdown
-User scaleable bar graph display
-User selectable waste gate delay for quick turbo spool
-External warning lamp driver
-No external interface required for programming
-Easy to install harness allows for quick and easy installation
-Boost hose and fittings included for easy hookup to on-board pressure sensor
-Multi-Bezel system: includes silver and black bezels, white and black face plates
AEM UEGO Wideband O2 52mm Gauge
AEM's Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM's Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED needle that changes colors as AFR changes from rich to lean. The unit's 52mm (2-1/16) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Key Features: Bosch sensor included with the AEM kit, 24 Color-coded LED display lights provide immediate reference to engine's air/fuel ratio (AFR) or Lambda, Integrated three-digit display reveals AFR or Lambda in real time user-programmable 0-5v analog output included for use with data loggers and ANY engine management system, Ideal AFR monitoring tool for carbureted applications and engine dynamometers, does not oscillate AFR like narrow band sensors, serial data stream included for output of AFR (RS 232), accurate to 0.1 AFR, 6 gauges in 1, one part number and you can have black or silver bezel with black or white face with a reading in lamda or AFR.
__________________________________________________ _______________
AMR BIG MAF Cold Air System 04-07
MADE IN THE USA!
All AMR parts are made in house!
The AMR BMI Cold Air System is hand built in-house to ensure fitment and quality. All of the BMI Systems come coated in either wrinkle red or our custom silver flake.
SPECS:
The *NEW* AMR Big Maf Cold Air Intake System is one of many products lined up for the new 2008 season. This intake has a diameter of 74mm making it one of the biggest on the market. Taking advantage of the 2008's unique body style, we have designed a cold air system giving the vehicle fresh air rather then under the hood absorbing excessive heat from the engine.
WHAT DOES IT COME WITH?
This intake system comes with "coated" intake piping, silicone couplers, clamps, bracket, and K&N cone!
AVAILABILITY:
Currently - 2004-2007 Subaru WRX / 2004-2007 Subaru STi
COLORS / OPTIONS:
This intake system is available in wrinkle red and, as shown above, our custom silver flake.
FITMENT:
Will fit with APS Front Mount Intercooler and AMR Front Mount Intercooler
AMR STi/WRX Turbo Back Exhaust 04-07
For hard hitting boost and acceleration, the AMR FULL 3 inch Turbo Back Exhaust System offers a bell mouth design for smooth exhaust entry and dual high flow resonator for perfect back pressure without the loss in power. The down pipe comes fully heat treated and coated to keep tempatures down, increase power and keep quality look. Our exhaust was designed for maximum flow and horsepower increase. Air fuel bungs are precision welded in the exact location for factory sensors and any additional hardware added. A bolt-in silencer is included for those who want a mellow sound. Kit indcludes all new gaskets, mounting hardware and instructions.
Note: These exhaust systems are built in house to ensure perfect fitment.
PM FOR $$PRICES$$
__________________
[LEFT][SIZE=1][B][COLOR=red][SIGPIC][/SIGPIC][/COLOR][/B][/SIZE]
[SIZE=1]
[/SIZE]
[FONT=Century Gothic][B]Instant Messenger:[/B] [COLOR=red][I][B]AMR Performance[/B][/I][/COLOR][/FONT]
[SIZE=1][COLOR=black][B]
[/B][/COLOR][/SIZE]
[SIZE=1][FONT=Lucida Sans Unicode][COLOR=black][B]ECU SOFTWARE & PERFORMANCE PARTS MANUFACTURER[/B][/COLOR][/FONT][/SIZE]
[/LEFT]
AMR is offline
Old 07-07-2008, 11:51 AM   #2
AMR
NASIOC Manufacturer
Member#: 171509
Default AMR Built Motors
AMR SHORTBLOCKS
Looking for a Shortblock? Amr Shortblocks are Dyno proven and track tested. Choose from a variety of different power levels to build your own custom beast.
New USDM STi Semi-Closed Block
AMR Performance R-Spec Aluminum Pistons (Turbo / Nitrous)
New USDM STi Rods
Forged Crankshaft
All of our motors come with our exclusive signature series pistons. These pistons come with "DEEP VALVE NOTCHES" to accept oversized valves and extremely high lift cams. Our pistons are designed for nitrous and turbo application. Our pistons are built using the best in high quality silicone based aluminum to handle extensive horsepower and high tempature. (any compression desired is available).
AMR Performance R-Spec Rods
AMR Performance R-Spec Aluminum Pistons (Nitrous / Turbo)
Forged Crankshaft
Balanced and Blueprinted
New USDM STi Semi-Closed Block.
AMR Performance "1600hp Tested" Pro-Billet Rods.
AMR Performance R-Spec Aluminum Pistons (Nitrous / Turbo). - FULLY COATED!!!
Forged Crankshaft.
Balanced and Blueprinted.
AMR RC Series Shortblock "The NEW Breed"
The AMR "Race Competition" (RC) Short Block is what we call "The NEW Breed" of Subaru Performance. This short block comes with our new "AMR SIGNATURE SERIES" high compression pistons. These pistons have been custom made to our specifications to ensure top quality and performance. The compression has been raised from the normal 8:2.1 to a choice of 9:5.1 or a high 10:1. The huge increase in compression will gaurantee a big increase in spool up, torque and 60ft quarter mile times. These pistons will also accept a HUGE camshaft due to the AMR SIGNATURE SERIES pistons having huge cam valve relief.
This Short Block comes with:
- New USDM STi Semi-Closed Block
- AMR Performance Spec 1600hp Pro-Billet Rod
- AMR Performance Signature Series High Compression Aluminum Pistons
- Forged Crankshaft
- Balanced and Blueprinted
This shortblock can be used for STREET and STRIP!!!
PM FOR $$PRICES$$
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-07-2008, 11:51 AM   #3
AMR
NASIOC Manufacturer
Member#: 171509
Default 2008 STi/WRX Products
The 2008 STI/WRX AMR Parts List
2008 AMR BMI System
MADE IN THE USA!
The AMR BMI Cold Air System is hand built in-house to ensure fitment and quality. All of the BMI Systems come coated in either wrinkle red or our custom silver flake..
SPECS:
COLORS / OPTIONS:
*NOTE:
The AMR BMI System is 70mm+ in diameter. You will need to either run our AMR S1 map or a custom tune in order to scale the correct air to fuel mixture. Otherwise the vehicle will run lean and cause mechanical problems.
The new style 2008 STi has come a long way from its older brothers. With the new AVCS Exhaust Cams and extremely intelligent ECU. The 2008 STi is one of perfection. We at AMR have our own 2008 STi in house in which all testing and product development takes place. AMR S1 Package has sling shot the new 2008 STi into the high 12's in the quarter mile. Making the 2008 AMR STi first in the 12's.
AMR Stage 1
Our AMR-S1 Kit gives you a healthy increase in power. Not only in drivablilty, but an noticeable increase all through out the RPM band.
Stage 1:
Track E.T.: 12.9 - 13.2
Track MPH: 108mph-110mph
Modifications:
1) COBB AccessPort v2.0
- Custom AMR Map
2) AMR BMI Cold Air System
AMR 750cc Injectors
The AMR 750cc Injectors right on the money. Tested and flowed to a perfect 750cc. These injectors are as top quality as you can get. Nothing over looked. Complete plug-n-play for easy installation. No HARD wiring under the hood.
These injectors are included in our staged packages along with a custom dyno tuned map. Making everything a complete plug-n-play. So your only down time on the vehicle would be the parts install.
AMR T50R Turbocharger (bolt-on)
One of the most fun drivable turbochargers on the market. Achieving full boost around 3000rpm-3600rpm (depending on modifications) causes the driver to get extremely throttle happy! Designed for those who want that QUICK SPOOL and TOP END POWER. The AMR T50R has a fully ported compressor housing and fully ported 7cm2 exhaust housing giving the turbocharger maximum flow. Along with the optional 3" compressor housing, this turbocharger is a fully done 50 trim jammed with all of the goodies making it the best bang for the buck! Power levels range in the 330whp-400whp mark.
T50R Specs:
- 750-770 cfm
- 7cm2 exhaust housing
- 2.4" Compressor Inlet (optional 3" compressor inlet)
- Fully ported exhaust housing
- Fully ported compressor housing
- HIGH TEMP coated exhaust housing (increase spool time)
- OIL AND WATER COOLED!
- Includes ALL oil and water lines
- DIRECT BOLT-ON
OPTIONAL CUSTOM 19-24 psi Acuator
Optional:
Just when you think it couldn't get any better. We can include the optional 19-24psi Custom Built Actuator for an addition $190.00. This actuator is for those running heavy boost. This wastegate combined with the T50R makes boost taper a thing of the past. We have tested the T50R with this actuator holding boost straight to redline.
The CUSTOM actuator made for our T50R by FORGE is a thing of beauty.
AMR Top Mount Intercooler (TMIC)
20"L x 12"W x 4"H
The AMR Top Mount Intercooler (TMIC) puts the stock intercooler to shame. With a dimension of 20"L x 12"W x 4"H it dominates over the stock tmic. The AMR TMIC is designed to cool down the air charge to the engine which in turn gives the vehicle better response, more torque and more power. The AMR TMIC has been tested at over 30+ psi.
FITMENT:
PERFECT! No fighting with clamps, brackets or fire wall issues. Intercooler's are fully assembled. All T-Bolt clamps, gaskets and couplers included. So just take it out of the box and slip it on the car.
FEATURES:
The AMR TMIC really differs from others. The intercooler is upgraded with a 3" outlet rather than the 2.5" that comes standard on competitors. Allowing more room for air to travel out of the core into the engine.
We have noticed with upgraded turbochargers, the upper coolant line hits the intercoolers. So we have modified a inverted lip on the end tank.
We also BEEFED up the material used on the flanges. Making them practically un-bendable. All flanges are made from 6061 aluminum.
COLOR CHOICES:
- BLACK w/ AMR logo in white
- Brushed Aluminum w/ AMR logo in black
PM FOR $$PRICES$$
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-07-2008, 11:52 AM   #4
AMR
NASIOC Manufacturer
Member#: 171509
Default Utec!!!!
Turbo XS Delta v2.0 UTEC for
02-05/06-07 WRX & 04-07 & 08 STi
Turbo XS Delta v2.0 UTEC Engine Management for WRX & STi
The Turbo XS UTEC is a new concept in engine management that combines the features of a stand-alone engine management system with the simplicity of a piggyback system. The UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over basic day-to-day functions.Functions like cold start, hot start, intake temperature compensation, AC compensation and closed-loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend more time driving and less time tuning for stock functions.UTEC Standard
Features:
PLUG & PLAY: Installs in minutes on top of the factory computer using all the factory connections.
END-USER PROGRAMMABLE: Fine tune maps via a laptop equipped with a serial cable and Hyperterminal.
PRE-PROGRAMMED BASE MAPS: Standardized maps are available for common setups (i.e. turboback exhaust, upgraded intercooler, bigger turbo & injectors, etc.) Maps can be uploaded and downloaded easily. Not currently available for the Legacy GT.
5 MAP MEMORY: 5 maps can be stored at a time, and using the remote map selector, you can quickly switch into valet mode, stock mode, nitrous, or race fuel maps with the click of a switch.
FUEL, TIMING, AND BOOST ARE USER-PROGRAMMABLE: in 250rpm increments up to 9000rpm over 10 load sites.
COMPLETE IGNITION TIMING CONTROL: No need to worry about the factory ECU pulling timing anymore; be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map
FUEL CONTROL: Controlled via MAF sensor signal offset, tune stock and larger than stock injectors; pre-set injector correction (just type in the size!).
LOAD REFERENCE: MAP (manifold pressure)
CLOSED LOOP BOOST CONTROL: Programmable via throttle Position and RPM. No more re-adjusting the boost controller due to changes in temperature or altitude. Keeps boost low while in closed loop fuel mode for reliability.
KNOCK CONTROL: Automatically retards timing when the knock is detected safeguarding against engine damage. Adjustable knock threshold, timing correction, and duration.
ON-BOARD DATA LOGGING: Displays all necessary data required for tuning, including wideband AFR when used in conjunction with the Turbo XS Tuner.
BUILT-IN PROGRAMMABLE SOLENOID CONTROLLER: Control nitrous, water injection, intercooler water spray or any other solenoid device.
ADDITIONAL FEATURES: Drag racing launch control (secondary rev limit used during launch). All UTEC software downloads and upgrades are free and available from Turbo XS's website.
1 YEAR WARRANTY
FITMENT:
2002-07 WRX
2004-07 STi
Delta Utec 02-05 WRXtxs-DELTA-001
Delta Utec 04-06 STitxs-DELTA-002
Delta Utec 06-07 WRXtxs-DELTA-003
MSRP - $1046
Turbo XS Delta v2.0 UTEC Engine Management for STi
The Turbo XS UTEC is a new concept in engine management that combines the features of a stand-alone engine management system with the simplicity of a piggyback system. The UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over basic day-to-day functions. Functions like cold start, hot start, intake temperature compensation, AC compensation and closed-loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend more time driving and less time tuning for stock functions.UTEC Standard Features:
FITMENT:
2008-00 STi
Delta Utec 2008-09 STi txs-DELTA-003
MSRP - $1046
PM FOR $$PRICES$$
AND SAVE THE BEST FOR THE LAST!!!!!!!
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-07-2008, 11:53 AM   #5
AMR
NASIOC Manufacturer
Member#: 171509
Default AMR SALE!!!!!!!!!!!! ***AEM Gauges & METH**********
Auto Master AMR / AEM SALE!!!
AMR / AEM packege deal includes:
- AEM Water/Methanol Injection
- AEM UEGO Wideband 02 52mm Guage
- AEM TRU-BOOST Controller
All Included for $945.00 SHIPPED
So you get the AEM Water/Methanol Injection Kit, AEM UEGO Wideband 02 52mm Guage and the AEM TRU-BOOST Controller all for $945.00 SHIPPED!!!!!!!!!!!!!!!!
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-07-2008, 01:55 PM   #6
CO WRX
Member Sales Rating: (10)
Member#: 8719
2008 06 FXT, 08 STi
Grey, White
PM Sent
CO WRX is offline
Old 07-08-2008, 10:26 AM   #7
rex2281
Member Sales Rating: (39)
Member#: 128808
2002 wrx sedan
black
sent you a pm but never responded
rex2281 is offline
Old 07-08-2008, 11:13 AM   #8
AMR
NASIOC Manufacturer
Member#: 171509
PM SENT!!!
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-08-2008, 12:44 PM   #9
C J
Member#: 132587
2006 JrTuned STi
[email protected]
What is the pricing on the TMIC?
C J is offline
Old 07-08-2008, 04:05 PM   #10
AMR
NASIOC Manufacturer
Member#: 171509
Sent!
ALL PM's REPLIED!
-Rob/Mark
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-08-2008, 10:37 PM   #11
oscargarza88
Member Sales Rating: (7)
Member#: 115984
2006 impreza STI
hi,
can i have the price on the AEM meth kit and on the TMIC?
oscargarza88 is offline
Old 07-09-2008, 12:03 PM   #12
AMR
NASIOC Manufacturer
Member#: 171509
BUMPITY BUMP!
Originally Posted by oscargarza88 View Post
hi,
PM SENT!!!
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-11-2008, 10:44 AM   #13
AMR
NASIOC Manufacturer
Member#: 171509
PM's ANSWERED!!!!
Morning BUMP!
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-11-2008, 11:31 AM   #14
subaruwrx04
Member#: 125967
2005 sti
price on tmic please
subaruwrx04 is offline
Old 07-11-2008, 12:58 PM   #15
AMR
NASIOC Manufacturer
Member#: 171509
PM SENT!!
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-16-2008, 08:47 PM   #16
thats imprezive
Member Sales Rating: (1)
Member#: 155991
price on tmic, t50r turbo, and aem meth kit?
thats imprezive is offline
Old 07-16-2008, 08:52 PM   #17
thats imprezive
Member#: 155991
Old 07-17-2008, 09:23 AM   #18
AMR
NASIOC Manufacturer
Member#: 171509
ALL PM's ANSWERED!!!
T50R TRACK RESULTS ARE IN: http://forums.nasioc.com/forums/show...&highlight=amr
-Rob
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 07-18-2008, 04:47 AM   #19
AKLGT
Member Sales Rating: (11)
Member#: 85199
2012 turbo rollersk8
EvolvedAK's hood ornament
Damn, Rob! amazing products!!!
AKLGT is offline
Old 07-20-2008, 11:50 AM   #20
CTKNY
Member Sales Rating: (38)
Member#: 152700
i sent you a pm months ago about a aquamist hfs5 kit. I want to pick it up but noone ever got back to me..
You did beat eveyones price on the board that i asked
CTKNY is offline
Old 07-20-2008, 03:54 PM   #21
sanjay
Member#: 100624
2004 WRX Wagon
How much for the super-street (SS25) shortblock and the PRO-Street (PS25) shortblock shipped to 94122?
Thanks.
sanjay is offline
Old 07-20-2008, 11:49 PM   #22
lunatic meth
Member Sales Rating: (8)
Member#: 106448
02 WRX Stg. II
Midnight Black Pearl
can i get a price on the TMIC?? Thanks
lunatic meth is offline
Old 07-21-2008, 08:40 AM   #23
AMR
NASIOC Manufacturer
Member#: 171509
Default July Sale
Thanks.
ALL PM's ANSWERED!!!!
-Rob
__________________
[SIZE=1]
[/SIZE]
[/B][/COLOR][/SIZE]
[/LEFT]
AMR is offline
Old 09-25-2008, 03:26 AM   #24
CGMsti07
Member Sales Rating: (2)
Member#: 162437
2007 STI
Gray
how much for the AMR BMI Cold Air System. in wrinkle red for a 07 sti shipped to 98208?
CGMsti07 is offline
Closed Thread
Turbo Xs, Aem, Element Blowout AMR Gauges & Electronics 12 02-22-2009 04:22 AM
FS: TDO4 Turbo, Turbo XS MBC, WRX TMIC and more jp102895 Engine/Power/Exhaust 4 09-03-2008 12:56 AM
FS: TDO4 Turbo, Turbo XS MBC, WRX TMIC and more jp102895 TXIC Private Classifieds 2 08-28-2008 10:44 PM
AVO turbo inlet, JDM V7 TMIC, PLX wideband O2, gauging intrest ej255 shortblock big67 Engine/Power/Exhaust 22 06-21-2007 02:41 PM
Till the end of the week crazy sale on TURBO XS Parts. Especially TMICs! WorldOne Engine/Power/Exhaust 13 03-22-2005 11:39 AM
