Old 07-07-2008, 02:01 PM   #1
The Blue Pilot
Member#: 101880
2012 Mustang GT
Default Battery trouble
For the records, mine went out at 3 years 2 months, 48,xxx miles.
Couple quick questions:
1) Is there anything involved with replacing a battery other than the 2 bolts holding the + and - wires in and the 2 bolts holding the battery down?
2) Should I stick with a new OEM battery, or are there some aftermarket proven to be better?
Thanks.
The Blue Pilot is offline   Reply With Quote
Old 07-07-2008, 02:25 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Battery removal is very simple, but when you get a new one you need to specify that you have an import, as the battery terminals are on opposite sides on standard batteries. If you don't have any need for a fancy battery, an OEM one, DieHard, Interstate, whatever, they'll all work fine. I'm willing to bet that the OEM battery is as expensive as the others out there, so you might look into an upgrade, but for ease of install you can't beat the OEM.
Audiosavvy is offline   Reply With Quote
Old 07-07-2008, 02:36 PM   #3
BluScubi
Member#: 162726
2009 LGT
QSM
I payed 72 for my oem. But I work at another dealer across the parking lot so I got a discount. It would prolly run you like 90 or so.
BluScubi is offline   Reply With Quote
Old 07-07-2008, 03:41 PM   #4
The Blue Pilot
Member#: 101880
2012 Mustang GT
^^thanks for the detailed help guys. I'll just stop by the dealership today and pick one up.
You guys think it's worth paying $90 to get one from the dealership or is it worth picking up a random battery brand new for $30 (hook up) so long as it fits and the + and - are on the same sides?
Old 07-07-2008, 03:54 PM   #5
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Any battery for $30 is not worth the cost of gas to drive and pick it up. The OEM at $90 really isn't a bad price considering the increase in the cost of batteries the last few years. For example, the least expensive battery I sell at my store is $175 (Optima).
Old 07-09-2008, 09:28 PM   #6
sxotty
Member#: 95600
2003 WRX wagon
I have a random question.
My battery is the original, has 75k miles on it now.
So it seems the corrosion on the battery has been getting way worse. At first it barely corroded at all, then it got quite bad and I cleaned it up with baking soda etc, put a bit of anti corrosion stuff on it, and the felt pads. A while later I looked and it was worse than ever had to replace the ground wire as it split the insulation the wire was swelling from corrosion, and the battery was doing worse. Cleaned it up again another bit later I looked and the corrosion was back and even worse and faster growing it seemed.
Do old batteries or ones with leaks corrode faster?
I am about to replace the battery now and am thinking of an optima red top model 35 as it is an AGM type so there is no liquid to leak out etc... will the reduce corrosion? Is there something else I should try to do?
(And it is forming not just on the terminals, but also battery hold down bar).
sxotty is offline   Reply With Quote
Old 07-09-2008, 10:29 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If it's corroding that much and that fast, you may have a bad cell which is boiling out electrolyte. Also the regulator may be bad and allowing the voltage to run too high which will overcharge the battery and also boil out electrolyte.
You can check the voltage with a meter, with the engine running at operating temperature it shouldn't be more than 14.5V.
If your OEM battery has made it to 75K you're lucky but it would be a good time to replace it. You're correct about an AGM battery not having corrosion issues, since there is no liquid electroylte and they do not vent gas under normal circumstances.
Old 07-14-2008, 10:19 AM   #8
mike moniot
Member#: 5999
'02 wrx spt wagon
I replaced 1st time with a Sears Die Hard Gold South in late Mar 2005 ($79.99 + tax and recycle charge)
It died 7 July 2008.
mike moniot is offline   Reply With Quote
Old 07-14-2008, 11:57 AM   #9
sxotty
Member#: 95600
2003 WRX wagon
Thanks man.
I did check the voltage previously and it was A-OK. I am trying to wait till my CC payment rolls over to buy the new AGM one (so I can pay for it a month later ).
97 OBS trouble starting.. not the battery... nperkins Electrical & Lighting 3 01-27-2010 09:52 AM
Car Battery Issues - Trouble Starting Cky47 Electrical & Lighting 6 01-14-2010 10:03 PM
Q's Trouble with catch can Extreme trouble moorebl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-24-2007 09:37 AM
Battery trouble 04 sti Java Blizack Electrical & Lighting 6 06-12-2006 10:00 AM
Trouble hooking battery line back up wRxbeater11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-11-2004 11:17 AM
