Old 07-07-2008, 01:35 PM   #1
acssa
Member#: 184023
Default massive jerk coming off the throttle
I have an 07 sti and I put APS CIA 65, 725 FMIC, BOV and HKS EVC6.
The car is now behaving strange serge, on steady 1/4 - 1/2 throttle...
BUT WAIT THERE IS MORE...
You get a single jerk of note coming of the throttle on a up hill full throttle.
Can anyone please help????
"From South Africa"
acssa is offline   Reply With Quote
Old 07-07-2008, 05:18 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
That is throttle-off compressor surge - your BOV is too tight. Put a lighter spring in it - it should barely be closed at idle vacuum.
flycaster is offline   Reply With Quote
Old 07-08-2008, 12:55 PM   #3
acssa
Member#: 184023
You do know your STUFF!!!
Two tuner shops could not fix it... even the one selling the bov.
Thanks alot
One last question
What would you choose, Cosworth or Brian Crower intermals?
Old 07-08-2008, 01:54 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
I answered that in your pm.
Moving the MAP sensor off the throttle body question Hayaboosted Factory 2.5L Turbo Powertrain 6 04-30-2010 12:21 PM
massive blowby coming from the crank case. ownnij Built Motor Discussion 8 04-24-2010 09:53 PM
Jerking coming off WOT acid7711 Factory 2.0L Turbo Powertrain 6 09-21-2009 08:00 PM
massive jerk coming off the throttle acssa Engine Management & Tuning 4 07-14-2008 03:57 PM
Throttle Blip After Coming off the Throttle? Shaved Factory 2.5L Turbo Powertrain 18 04-05-2005 07:44 PM
Message Board Statistics All times are GMT -4. The time now is 12:21 PM.
