Old 07-07-2008, 03:06 PM   #1
avi1777
Member#: 147652
02 sti
white
Default cams
will i feel a major diference if i will put 272 cams(kelford) on a build sti with gt35r?
i understood that the stock cams are good but the 272 will work the gt35 much better
does it worth the time and money?
thanks
avi1777 is offline   Reply With Quote
Old 07-07-2008, 03:14 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
You are opening up a big old can of worms. The cams will be very beneficial. You will most likely need to replace a lot of valve buckets and/or have the valvestems ground down to get the valve lash in spec. You should replace the springs/retainers as well, and your fuel system might need to be upgraded to handle the extra high rpm airflow.
jays05 is offline   Reply With Quote
Old 07-07-2008, 05:35 PM   #3
avi1777
Member#: 147652
02 sti
white
thanks
Old 07-07-2008, 09:05 PM   #4
blue05
Member#: 125144
2005 wrx STi
wrb
My buddy has the kelford 272's on his 2.5 with a perrin 35r kit. He is friends with a very reputable northern pacific area tuner, that has tuned an exact copy of his car with the only difference being the 272's. His car with the cams made 50+ more hp and about the same amount more torque. Yes the powerband did shift a little but not much. He only revs to 7500rpm. Plus, if you have a quiet catback you don't even notice the car has cams, even more so with equal length headers. I plan on using the kelford 272's as well now that I know they are so mild mannered.
blue05 is offline   Reply With Quote
Old 07-07-2008, 09:51 PM   #5
blue05
Member#: 125144
2005 wrx STi
wrb
^^yes^^
I forgot to mention. He also installed new springs/retainers (I think it was a bc set) and had the valve tips ground to get the correct lash.
Old 07-07-2008, 11:43 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Are you talking about the 272 AVCS cams? Just wondering because my 272's w/ Kelford ground lope like a mother(non-AVCS)
Old 07-08-2008, 08:08 AM   #7
avi1777
Member#: 147652
02 sti
white
did you mean 50whp or 50hp?
Old 07-08-2008, 11:04 AM   #8
dmross
Member#: 2818
2000 2.5RS
+1
My non-AVCS Kelfords lope like mad... and I love it.
I picked up 80whp changing from STI 5/6 cams (EJ207 heads).
dmross is offline   Reply With Quote
Old 07-08-2008, 11:06 AM   #9
dmross
Member#: 2818
2000 2.5RS
+1
My non-AVCS Kelford 272s lope like mad... and I love it.
closed subydude02 Engine/Power/Exhaust 41 08-11-2010 08:29 AM
Scorpion cam. Cow cam. Coyote Cam. Frog cam. Jessie James Off-Topic 3 08-31-2009 01:50 PM
Cams, Cams, and More Cams impr25rs Normally Aspirated Powertrain 35 03-25-2008 08:31 PM
turbo cams or n/a cams flent Normally Aspirated Powertrain 19 04-02-2001 09:00 AM
