Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Closed Thread
Old 07-07-2008, 03:12 PM   #1
Edo Performance
Vendor Sales Rating: (54)
Member#: 70537
Default EDO Performance: 2008 Summer Specials on Performance and Maintenance!
Feeling the heat! Edo is now certified to perform A/C repairs and to do performance testing!
Summer is already here! New WRX's, New STi's, New parts to install! Okay...just another excuse to give you all discounts on our services. With hot temperatures comes hot hot hot prices!!!!!!
Oil Changes
- Mobil 1 5W-30 Synthetic Motor Oil with Zero/Sports Oil Filter WAS $68 NOW $60
- Motul 5W-30 Synthetic Motor Oil with Zero/Sports Oil Filter WAS $75 NOW $70
- Motul 300V 5W-30 Synthetic Oil with Zero/Sports Oil Filter WAS $99 NOW $90
Transmission and Differential Fluid Changes
- Transmission: Motul 75W-90 Synthetic Gear Oil WAS $110 NOW $100
- Differentials: Motul 75W-90 Synthetic Gear Oil WAS $70 NOW $65
- COMBO Trans and Diff: Motul 75W-90 Synthetic Gear Oil WAS $175 NOW $150
Radiator/Coolant Fluid Changes
- RedLine Water Wetter WAS $69 NOW $65
- Motul Inugel Optimal Organic WAS $69 NOW $65
- Motul Inugel Expert Hybrid WAS $79 NOW $75
Brake Services
- *Motul Brake Fluid is used on EVERY Brake Service!
- **Add an additional $7 for Motul RBF600 Fluid!
- Zero/Sports Stainless Steel Brake Lines (Front and Rear) $240 INSTALLED!
- Zero/Sports Front "Street" Brake Pads $175 INSTALLED
- Zero/Sports Front "Sport" Brake Pads $225 INSTALLED
- Zero/Sports Front "Circuit" Brake Pads $255 INSTALLED
- Zero/Sports Rear "Street" Brake Pads $165 INSTALLED
- Zero/Sports Rear "Sport" Brake Pads $215 INSTALLED
- Zero/Sports Rear "Circuit" Brake Pads $245 INSTALLED
- COMBO Front and Rear Pad Packages available! Please PM for pricing!
Clutch and Flywheel Installations
Clutch/Flywheel Install $500*
* Motul Gear Oil will be used to refill your transmission.
Factory Mileage Maintenance Services
30,000 Mileage Service
- Inspection of drive belts and camshaft belts
- Inspection of fuel system, lines, and connections
- Inspection of air filter (replaced with Zero/Sports N1 Filter if necessary)
- Inspection of brake pads, linings, and lines
- Inspection of ATF/Power Steering Fluid
- Inspection of front and rear axle boots and axle shaft joints
- Inspection of clutch, steering, and suspension systems
- Inspection of tires (and rotation if permitted)
- Engine oil replacement with Motul 5W-30 Synthetic Motor Oil
- Engine oil filter replacement with Zero/Sports Oil Filter
- Engine coolant replacement and system/hose inspection for cracks/leaks
- Transmission and Differential fluids replaced with Motul 75W-90 Synthetic Gear Oil
- Brake fluid replaced with Motul Brake Fluid**
- WAS *$480! NOW $470
60,000 Mileage Service
- 30,000 Mileage Service is performed
- Fuel Filter replaced
- Spark Plugs replaced
- WAS *$560! NOW $550
90,000 Mileage Service
*Additional fees may be added for automatic transmission vehicles and for replacement of air filter. Customer will be notified of charges in advanced.
**$7 additional fee if Motul RBF600 Brake Fluid is requested
Stay tuned as I will keep this thread constantly updated with up-to-the-minute sales and installation specials!
We also stock a lot of Motul Fluid
Motul
8100 5W30 Oil - Call/PM for Price!
8100 5W40 Oil - Call/PM for Price!
300V 5W30 Oil - Call/PM for Price!
300V 5W40 Oil - Call/PM for Price!
75W90 Gear Oil - Call/PM for Price!
90PA LSD Oil - Call/PM for Price!
Dextron III ATF - Call/PM for Price!
Inugel Expert Coolant - Call/PM for Price!
MoCool Radiator Additive - Call/PM for Price!
RBF600 Brake Fluid - Call/PM for Price!
Thanks folks!
-Robert
EDO Performance
16182 Gothard Street, Unit P
Huntington Beach, CA 92647
714-602-5741 ext. 15
__________________
U.S.A. Master Distributor for:
Cusco, Tomioka Racing, Zero Sports, Motul
Phone:(714)602-5741
Follow us on:
Edo Performance is online now
Closed Thread
Virginia Beach:2/16/2008 VF39 Install on WRX and a few extras rwdCivic Mid Atlantic Impreza Club -- MAIC 6 02-17-2008 12:33 AM
Summer Specials on Staged Brake Packages, Suspension Goodies, You Want It, We Have It GreyMotorsports Suspension/Brakes/Handling 0 07-01-2007 07:30 PM
Summer Special On Wheels (WORK + 5 Zigen) !!! RavSpec Wheels/Tires 43 11-24-2005 05:25 PM
Summer Special On Exterior Parts !!! RavSpec Exterior/Styling 91 10-12-2004 11:40 AM
Message Board Statistics All times are GMT -4. The time now is 11:24 AM.
