Old 07-07-2008, 05:02 PM   #1
iRick.
Member#: 158155
Default a little hardwiring help..i think.
if that is what you call it. i have a little project here and i wanna see if it can be done.
for the 2007 impreza, where the lighter and the little coin change pocket it, i am wondering if it is possible to remove those two pieces, and put in a navigation system
obviously only if there is one small enough to do so.
if there is one small enough to do so, how would i wire it up to run from the car, etc?
sorry guys, i'm a huge n00b when it comes to wiring and this idea just popped up into my head
iRick. is offline   Reply With Quote
Old 07-07-2008, 05:29 PM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
the navi system will come with a harness with pigtails off the end. just cut the wires powering the power socket and wire them in... should be that simple. as far as mounting goes... I dont know how thats gonna go for ya.
ProdriveDreams is offline   Reply With Quote
Old 07-07-2008, 05:43 PM   #3
iRick.
Member#: 158155
yeah..i was thinking of simply making a custom box..but i don't think there is a navi small enough to fit in that area.
does anyone know if there is?
Old 07-08-2008, 03:58 AM   #4
Miercoles Cansado
Member#: 166820
my ignore list
Have you thought of replacing the factory radio with one that has built in nav? It would probably be easier, look better and easier to see.
Miercoles Cansado is offline   Reply With Quote
Old 07-08-2008, 09:58 PM   #5
iRick.
Member#: 158155
that is the problem. i already have a new headunit [not cheap either]
i may just use that section for gauges instead. [once i need them that is]
Ipod hardwire help....its not working Dreammaster2.5RS Car Audio, Video & Security 6 01-22-2006 10:51 PM
A little local HELP!!! (tires) Jimmy S. Southern California Impreza Club Forum -- SCIC 28 07-23-2002 08:21 PM
A little VS0 help...breaking the crank bolt loose? STi2001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-18-2002 02:20 PM
('93-'01) A little vendor help... North Ursalia Impreza Forum 0 04-29-2001 10:31 PM
