Old 07-07-2008, 05:21 PM   #1
Valenti
Member#: 181227
1999 RSTI BDP (47a)
Full 2004 STI Swap
Default 2.5L USDM STI Block
I am building a solid 2.5 L sti block that I am going to swap into my 02 wrx after I drop in a 6speed.
So far for the block
I have ACL bearings
I need advice on pistons and rods, and if the sti crank is reliable.
I am essentially building a 400 awhp daily driver that is bulletproof.
Thanks for any comments or advice.
- Chris
Valenti is offline   Reply With Quote
Old 07-07-2008, 06:01 PM   #2
benw
Member#: 103320
1998 swapped
Forester L
Chris, while I haven't the firsthand experience, I can say that the STI crank should be fine for your goal of 400whp, based off what I have heard, and read. I have also heard that the stock rods are pretty good at that power level as well.
Pistons is tough, I had the same question as you, and found that a lot of people had great results with almost every manufacturer. The main thing I believe from research is that most pistons will work, but the machine work and tolerances must be spot-on for anything to work properly.
benw is offline   Reply With Quote
Old 07-08-2008, 12:41 AM   #3
Valenti
Member#: 181227
1999 RSTI BDP (47a)
Full 2004 STI Swap
I keep hearing really good thinigs about cosworth pistons and rods, but they can be pricey... I also like weisco and cp, but just am not sure what the best route is yet...
Old 07-08-2008, 02:36 AM   #4
86ray86
Member#: 172069
i used cp's and argo rods on my last build for 400hp atw on 16psi, they worked perfectly fine,,
86ray86 is offline   Reply With Quote
USDM 2.0 heads on a USDM STi Block? NicktheBrit Built Motor Discussion 5 03-06-2008 04:11 PM
How far can you safely overbore 2.5L USDM STI Shortblock skimobile Built Motor Discussion 7 07-13-2007 03:08 PM
V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads? saab-on-the-cobb Subaru Conversions 6 09-18-2006 07:03 PM
Weak points of the 2.5l stock STi block? neversatisfied Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 91 09-24-2004 12:51 AM
I'm Out Of STi Shortblocks- How About A 2.5L USDM STi Crate Motor Instead? subaruwrxparts.com Vendor 'For Sale' Classifieds 58 01-06-2004 12:58 PM
