Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 07-07-2008, 07:27 PM   #1
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Lightbulb Valve Adjustment Spreadsheet
Hey y'all. I am adjusting the valves in my EJ25D with the bucket lifters and shims, and I made a spreadsheet to help with it. I thought I'd share it with everyone...
I've got it up at google for now, if anyone has a better hosting place, let me know and I'd be happy to move it there where it retains the original format.
http://spreadsheets.google.com/pub?key=pOlZEvONctiaqMDEZEiL0fg&output=xls
EDIT: Google docs kinda messed up a couple of things. If you want the original copy shoot me a PM with the email address you want it sent to. Until I find somewhere to host it that will work =]
Let me know if you have any questions.
Aaron
Keywords: valve lash adjust clearance adjustment shim thickness bucket lifter EJ25 DOHC 2.5L maintenance valves spreadsheet formula chart
Last edited by fastenova; 07-09-2008 at 02:36 AM. Reason: added keywords for search
fastenova is offline   Reply With Quote
Old 07-08-2008, 10:01 PM   #2
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Cool - thanks. In metric and SAE. VN.
SBT
Subietonic is offline   Reply With Quote
Old 07-15-2008, 10:47 AM   #3
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Don't use this now, I'm correcting a couple of formulas! Also updating the shim SOA item number list. I'll update as soon as it's fixed.
Old 07-29-2008, 03:47 PM   #4
ruboy01
Member#: 57044
what sort of shim are these. A friend of mine has a engine that he's been working on and Subaru tells him that they don't exist. The car is an 04 wrx but the block is cast EJ25, I didn't look too close at the heads, but I saw the shims they are smaller than anything subaru has listed and they fit under the bucket, they're about half the diameter of the normal suby shims. Any help would be great.
ruboy01 is offline   Reply With Quote
Old 07-29-2008, 04:01 PM   #5
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
This spreadsheet is for EJ25 N/A motors. Specifically the Phase 1 DOHC motor. The shims on these motors sit on top of the bucket, and ride DIRECTLY on the camshaft.
I know nothing about the under-bucket shims used on other Subaru motors.
As far as SOA not knowing what they are, call another dealer and talk to a different parts guy. If it is a USDM Subaru motor they should know what parts go in it, or be able to look them up. If the parts person didn't know, he's an idiot.
Later WRXs came with 2.5L motors instead of the 2.0L motors, but I'm not sure what year they switched over. If the motor is an '06, make sure the parts counter guy knows that.
Old 05-26-2013, 01:37 PM   #6
zneubauer
Member#: 356617
did you ever get the updated version???
zneubauer is offline   Reply With Quote
Old 05-26-2013, 04:04 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
As far as I can tell, the version that is linked is correct. (I only fiddled with the English units page, not the metric units.) Did you find an error in the way it works?
valve tick or valve adjust? ali dashty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-06-2008 06:15 PM
Valve adjustment w/ solid shimless lifters? scooby5 Service & Maintenance 5 11-11-2001 11:25 AM
Power increase by valve adjustment alone? jazzman Normally Aspirated Powertrain 3 08-11-2001 12:28 AM
Has anyone done valve adjustments MY99 2.5GT Normally Aspirated Powertrain 2 06-27-2001 05:55 PM
Valve adjustment Pinoy Southern California Impreza Club Forum -- SCIC 0 06-13-2001 10:42 AM
