Old 07-07-2008, 08:47 PM   #1
illini_wrx
Member#: 155844
Default 17x9 w/ 245 tires on an '03?
17x9 +44 offset, with 245 tires, and between -1.3 and -1.6 camber in rear. Car has coilovers. Will I need to modify the fenders? What about with 235 tires?
Thanks in advance
illini_wrx is offline   Reply With Quote
Old 07-08-2008, 01:47 AM   #2
JDM555
Member#: 151449
2007 Nissan 350Z
Carbon Silver
Uhhh...with +44, it shouldn't be too aggressive, but I would roll the fenders in the rear to be safe. You wouldn't need anything in the front unless your incredibly low or if your coilovers have a lot of travel. 235's would look too stretched and imo would not deserve the 17x9 wheel. Go 245's and roll the rear fenders and call it a day.
John
JDM555 is offline   Reply With Quote
Old 07-08-2008, 09:08 AM   #3
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
yes you will need to roll your rear fenders, even for a 235.
WRX8XB is offline   Reply With Quote
Old 07-08-2008, 10:55 AM   #4
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
im rockin 17x9 +30 with 245's, def. need to do some fender massaging.
B00st3dWRX is offline   Reply With Quote
Old 07-08-2008, 04:54 PM   #5
sigurd
Member#: 128721
2002 impreza WRX
psm
yup I had to roll the rears with 245 +48 8in wide wheel. But im also only running -.5 rear camber so that makes it harder to fit. With 1.5* I probably wouldnt have needed too.
sigurd is offline   Reply With Quote
Old 07-09-2008, 04:51 PM   #6
illini_wrx
Member#: 155844
would it be a bad idea to move up to 245/45/17? the tires i want are only in stock in that size. i figure if ill need to modify the fenders either way, then why not?
Old 07-09-2008, 04:54 PM   #7
sigurd
Member#: 128721
2002 impreza WRX
psm
personally I think thats to tall of a tire. It will make it that much harder to fit. There are peoplr running that size though.
Old 07-09-2008, 05:14 PM   #8
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
thats a 245/40/17
a 45 would be a tall tire and alot of meat
Old 07-09-2008, 05:14 PM   #9
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
thats a 245/40/17
Old 07-09-2008, 05:29 PM   #10
evilsti
Member#: 170253
2007 STI
Black....FTW
what offset are those wheels?
evilsti is offline   Reply With Quote
Old 07-09-2008, 05:32 PM   #11
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
+30
Old 07-09-2008, 05:42 PM   #12
zac5
Member#: 141702
06 apex silve Evo9
Wrong Fitment Crew #054
Originally Posted by B00st3dWRX View Post
+30
Do you need extend wheel studs to run this setup? any issue?
zac5 is offline   Reply With Quote
Old 07-09-2008, 05:59 PM   #13
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
nope none just alot of negative camber and some fender massaging
Old 07-09-2008, 06:19 PM   #14
zac5
Member#: 141702
06 apex silve Evo9
nice to hear.
what camber setting you running now?
Old 07-09-2008, 06:28 PM   #15
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
Originally Posted by zac5 View Post
nice to hear.
going in for alignment tomorrow or friday hopefully so i will let you know the exact numbers.
Old 07-09-2008, 06:53 PM   #16
wvrex21
Member#: 157037
2006 TBSS
B00st3dWRX, nice wheels
I dont have the slightest idea why I put that it was a 245/45/17, it's a 245/40/17. WOW! I feel like an idiot
wvrex21 is offline   Reply With Quote
Old 07-09-2008, 07:12 PM   #17
illini_wrx
Member#: 155844
Originally Posted by wvrex21 View Post
245/45/17
nice!!!
what are the specs on the wheels, your drop, your camber, and what you did to your fenders?
Old 07-09-2008, 07:45 PM   #18
wvrex21
Member#: 157037
2006 TBSS
Tokico DSpec struts, Swift R-Spec springs. The rear fenders were rolled. The wheels are a Rota Torque R +30 17x9. I too need an alignment
Old 07-09-2008, 09:04 PM   #19
JDM555
Member#: 151449
2007 Nissan 350Z
Carbon Silver
245/45/17 would be too much of a pain to fit. They will also look worse if you have 17x9, the thinner the better. Get 245/40, look around if you HAVE to have those tires that were out of stock. 235's are too thin and 255's are good, but you definitely need fender rolling and coilovers, maybe some pulling too.
John
Are the strut bodies on an '03 2.5 RS the same as an '02 WRX? lotarg Newbies & FAQs 3 05-27-2010 06:53 PM
Replacing one of 4 tires on an '03 WRX saqib11 Tire & Wheel 4 04-30-2010 03:05 AM
Anyone making 250 or more WHP on an '03? AntiochCali Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-06-2003 12:45 PM
Can you disable the Hill Holder feature on an '03 Forester? beastcivic Transmission (AT/MT) & Driveline 1 01-24-2003 08:13 PM
