Old 07-07-2008, 10:02 PM   #1
blue05
Member#: 125144
2005 wrx STi
wrb
Default Case bolts?
Forgive me if this has been touched already but I searched and didn't come across anything (There may have been some info but I have limited time to read).
Has anyone seen the ARP case bolts? Other than a little peice of mind what kind of monster build would you need to have to require the use of these bolts? Has anyone had problems with the stock case bolts? Damaging threads in block or on the bolt itself? Bent/stretched bolts?
O well. I may just buy these anyways just to say I have them.
blue05 is offline   Reply With Quote
Old 07-07-2008, 10:33 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Personally, thats the only reason I can think of.
Old 07-08-2008, 01:34 AM   #3
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
if you've opened up your stock case more than a few times, that's a reason to replace them....what build # are you on?
UP2MTNS is offline   Reply With Quote
Old 07-08-2008, 11:31 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I have them as I had planned to strap a 42R on but that's way down the road...so now its overkill for my 35R
That and I imagine I'll be diving into the block several times!
Old 07-08-2008, 11:52 AM   #5
charliew
Member#: 125304
I would think if they aren't over-torqued the threads would be nice and smooth and give a better torque reading. I don' remember if the case uses helicoils or not but that is the question as to how many times aluminium threads can be re-assembled especially if the bolts are over-torqued.
If the case is just aluminium then the bolts will last forever. The aluminium threads in the case will pull out before the bolts can be damaged.
charliew is offline   Reply With Quote
Old 07-08-2008, 12:03 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
mine will be getting helicoils on the next tear down...forget to clarify that part of the equation. Otherwise, you are right Charlie, the block would normally give first.
Old 07-08-2008, 10:30 PM   #7
blue05
Member#: 125144
2005 wrx STi
wrb
I'm just getting ready to do my first build. I saw these and thought that it was overkill, unless the threads on the bolts or the block are prone to damage. They sure sound cool though.
Does anyone know if the block threads are straight aluminum or are there inserts/helicoils already there?
Old 07-08-2008, 10:46 PM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I have stripped out a few bolt holes on the front, they were pure aluminum.
Old 07-09-2008, 01:32 AM   #9
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
All aluminum. What is the price for those block bolts? And are your sure they give you all the bolts, or just the 8 main bolts?
~Josh~
Old 07-09-2008, 06:41 AM   #10
Homemade WRX
Member#: 33782
96 bastard child
it is all the bolts and I can't recall how much I spent on them....
Old 07-09-2008, 11:50 AM   #11
Vmiz
Member#: 115744
just keep in mind you ll have to line hone the case
the few i ve used them on exspecially the front main will tighten the oil clearance up alot
Vmiz is offline   Reply With Quote
Old 07-11-2008, 02:32 AM   #12
UP2MTNS
Member#: 112405
2004 WRX Rally Car
they're expensive.....$500 online. I bought mine (at my tuner's request) for $270 online, but they don't list it for that cheap anymore. lol
Old 07-12-2008, 01:44 AM   #13
blue05
Member#: 125144
2005 wrx STi
wrb
the cheapest i saw them for was around $350
Old 07-12-2008, 03:27 PM   #14
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Like mentioned above, you SHOULD line hone after installing as the forces will change some. Remember a few thou on the mains is a bunch of change...
Sinister redlines is offline   Reply With Quote
need stock ej257 case bolts gfx2043 Private 'Wanted' Classifieds 0 05-04-2009 01:59 PM
How much torque on the case bolts??? w/arp case bolt kit hectowrx Built Motor Discussion 6 10-08-2008 08:55 PM
WTB: ej257 gasket kit, ARP head bolts and case bolts 69_Lex Private 'Wanted' Classifieds 3 02-20-2008 10:38 AM
Tightening Trans Case Bolts [email protected] Transmission (AT/MT) & Driveline 1 10-03-2007 01:51 AM
5mt case bolts jhargis Transmission (AT/MT) & Driveline 9 09-10-2006 10:05 PM
