Old 07-15-2008, 05:09 AM   #1
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
Default 06 2.5L looking for 330whp on 91
Coming soon.
2.5L ej255 with cp pistons and ported wrx heads
spearco tmic
750cc inj
APS inlet and intake
tgv deletes
Blouch dom 1
gruppe-s headers
perrin uppipe
injen dp catless
invidia N1 cb
Im hoping for around 330whp im at 5000 feet elev. too
subaruNV is offline   Reply With Quote
Old 07-15-2008, 02:44 PM   #2
xlr8ed
Member#: 104413
dont forget fuel pump.
xlr8ed is offline   Reply With Quote
Old 07-15-2008, 02:55 PM   #3
MS WRX
Member#: 117780
2004 WRX
STi topmount will be plenty and save $$$
MS WRX is offline   Reply With Quote
Old 07-15-2008, 06:09 PM   #4
subaruNV
Member#: 154549
2006 DOM 3 Powered
yes i do have the fuel pump too forgot that. and i already have all the stuff so just seeing what u guys think if i can get that power on 91
Old 07-15-2008, 09:06 PM   #5
jheeno
Member#: 177805
2007 WRX
which CPs did you use standard or overbore ?
did you just replace the pistons and leave the crank/rod/bearings ?
jheeno is offline   Reply With Quote
Old 07-15-2008, 09:10 PM   #6
subaruNV
Member#: 154549
2006 DOM 3 Powered
stock crank and rods
Old 07-16-2008, 05:59 PM   #7
Steel06STI
Member#: 129711
1999 2.5 RS
meth.
Steel06STI is offline   Reply With Quote
Old 07-17-2008, 03:53 AM   #8
subaruNV
Member#: 154549
2006 DOM 3 Powered
what about a differnet dom series turbo like a dom2 or dom3 or a pickla pickler or what ever blouch calls that wierd turbo lol
Old 07-18-2008, 01:24 AM   #9
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
TD06-8CM 20G with methanol. That should EASILY get you there, and then some
edit: Oh you're still using the stock trans..... Hmm, good luck with that
Audiosavvy is offline   Reply With Quote
Old 07-20-2008, 08:57 PM   #10
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
OK, we get it 5-speed trannies suck. Must we mention it every time someone talks about 300whp+
Old 07-22-2008, 07:14 AM   #11
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
Originally Posted by subaruNV View Post
Coming soon.
spearco tmic
750cc inj
tgv deletes
Blouch dom 1
gruppe-s headers
perrin uppipe
injen dp catless
invidia N1 cb
first save money on the pistons, you don't need forged pistons for the numbers you want. you can have a very safe tune and get 320whp. i dont think that knock will be much of an issue with that mix.
second dont buy the APS inlet and intake cost way to much for the low quality that the inlet pipe is and the new aem filters are much better( i personally just switched to a new aem filter after using the aps filter for 3 months and the power difference was 13 hp. not alot but that 13 hp more and probably 1-2 mpg more.)
i suggest taking the money you save on the pistons/install and put that towards a 6 speed. after you have swapped the trans then sell your 5 speed setup.
insted of aps try the perrin inlet tube w/ aem filter. cost less and is much better.
mikeis300 is offline   Reply With Quote
Old 07-29-2008, 03:24 AM   #12
kmurphy
Member#: 163257
2006 sti
obp
you wont make that kind of power on pump at 5k feet with the dom1. im from tahoe and it just wont happen. bigger turbo and you'll still have problems getting there. your going to need meth to get to you goal.
kmurphy is offline   Reply With Quote
Old 07-29-2008, 06:24 AM   #13
subaruNV
Member#: 154549
2006 DOM 3 Powered
well here is the thing. i already have all the mods on the car that r posted. i did blow my motor cuz i was dumb but now i have the mods i posted with the cp pistons and the works and i just got my dom 3R in the mail...... so what do u guys think......
thanks for any input
Old 07-30-2008, 02:06 AM   #14
kmurphy
Member#: 163257
2006 sti
obp
who are you getting tuned by? if ed is coming out there to tune, you wont make 330 on his dyno software
Old 07-30-2008, 12:35 PM   #15
karmasi16
Member#: 145243
2006 wrx wagon
Urban Gray Metallic
did you get ARP headstuds and cometic headgasket. when you put the pistons and did the head work?
karmasi16 is offline   Reply With Quote
AccessPort V2 for 04-06 2.5L WRX for sale! LiDrummer SCIC Private Classifieds 2 02-05-2008 03:50 PM
AP V2 04-06 2.5l and 06 2 pots! V8This MWSOC Private Classifieds 6 11-18-2007 10:54 PM
Will 06 2.5L WRX tranny fit on a 02-05 WRX? gopsu Transmission (AT/MT) & Driveline 10 03-28-2006 07:45 AM
Cobb Stage 2 user looking for opinion on next mod WRexxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 05-10-2005 04:31 AM
Looking for info on do-it-yourself 2.5L exhaust dvancleve South West Impreza Club Forum -- SWIC 7 04-03-2001 05:30 PM
