Old 07-08-2008, 04:08 AM   #1
86ray86
Member#: 172069
Default Brian crower 2.71 stroker kit ??
Hey Guys
im from australia and looking for some opinions from you guys that have used this kit and have pushed big hp with it. im looking to push 500-550kw atw with this kit, will the pro rods be able to cope. as there my main concern, any advice and feedback would be great...
86ray86 is offline   Reply With Quote
Old 07-08-2008, 11:35 AM   #2
WRX 2002
Member#: 11211
2004 STi
Rally Blue
1 KW is approx. 1.34 HP. So 670HP to 737HP. not bad expectations.
WRX 2002 is offline   Reply With Quote
Old 07-12-2008, 05:19 AM   #3
86ray86
Member#: 172069
anyone have any feedback on this kit, im looking at buying very soon as my 2.5 has been sold...
Old 07-12-2008, 03:57 PM   #4
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
I have one and its a great setup, just rather expensive to get fully going. The main reason is that not only is it a stroker setup but also a big bore. This requires the darton big sleeves for the 102mm bore. This alone adds about $1600 to the setup on top of the actual stroker kit.
Sinister redlines is offline   Reply With Quote
Old 07-12-2008, 04:04 PM   #5
novacivic
Member#: 117980
2005 sti
wr blue
why not go with and axxis 2.65l stroker
novacivic is offline   Reply With Quote
Old 07-12-2008, 05:50 PM   #6
86ray86
Member#: 172069
why? reasons ?
Old 07-12-2008, 06:04 PM   #7
86ray86
Member#: 172069
what kind of power you putting through it ? did you use the rings that cam with the kit or sorce your own ?
Old 07-12-2008, 11:06 PM   #8
SniperSVD
Member#: 168633
i think the problem with stroker kits this big is the piston speed. to me it seems that you are bound to break, i remember seeing titainium rods, cobb i believe,
SniperSVD is offline   Reply With Quote
Old 07-13-2008, 01:55 AM   #9
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Stroker having piston speed issues? No, in fact they are actually slower. However the main debate is rod ratio not speed. Not to mention the amount of stroke increased is small compared to other applications (79mm - 83mm = 4mm = .157" roughly 5/32")
A small block chev is 3.480" stroke vs a 383 is 3.750" = .270" a little over 1/4" big difference....
Old 07-13-2008, 07:02 PM   #10
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Long rod kits would really help our subie boxers. Anybody make a long-rod kit? The short search I did came up wanting....
bcblues is offline   Reply With Quote
Old 07-14-2008, 02:09 AM   #11
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
not in a stroker setup due to the assembly process on subies making the rods hang from the crank then after the case is together you install the piston and wrist pin. This makes the fact that the oil ring cannot cover the wristpin and theres no more room to push the pin higher on the skirt.
Old 07-14-2008, 11:09 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yup, someone does...
If I say more than that, I will definately get in trouble.
Old 07-14-2008, 11:15 AM   #13
Homemade WRX
Member#: 33782
96 bastard child
a stroker motor at the same RPM as a long rod, will have higher instantaneous accelerations in a subaru because you have to shorten rod ratio to stroke. Might want to rework your "slider crank model" again.
My long rod setup is 1.8:1 and the 2.71 stroker is 1.57:1
You can also assemble the block quite easily with a long rod setup. There is also room to push the ring package up without much sacrifice to the ring lands...
I KNOW this for a fact. I spent a few years designing and modeling my package.
Old 07-14-2008, 11:43 AM   #14
MS WRX
Member#: 117780
2004 WRX
Yes but MOST small block chevy engines dont rev to 8500rpm. The forces acting on the rod increases geometrically with rpm.
MS WRX is offline   Reply With Quote
Old 07-14-2008, 08:25 PM   #15
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Yes you are correct the forces do climb with rpm, and yes sb can rev to 8500 with lots of work. What you failed to see what I was saying is that the BC stroker doesnt gain all of its displacement from stroke but rather bore/stroke combination. My relation was just to show that there wasnt a huge change in stroke and that was all. So on....
Old 07-14-2008, 08:32 PM   #16
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Maybe I showed what I was getting at incorrectly, but I was totally agreeing with the stroker not having the best rod ratio. And yes the blocks can be assembled the other way as I have had to disassemble one this way also. Its just not as easy with setting the rod bolts otherwise it is a other method and yes theres nothing wrong with the wrist pin in the ring lands (I have had different platforms like this in the past).
I have watched your build and you are playing with some neat ideas, but you are not the only one. I too have 12 years playing with built engines (that I have built not bought) so theres no reason to get defensive or agressive. I realize just about anything can be done but I was more getting at the norm as far as assembly and not the exotic. My next big build is going to be a short stroke, long rod, huge bore oddity.
Old 07-14-2008, 08:33 PM   #17
MartinSTi05
Member#: 145145
2006 wrx STi
In the end we are interested in forces applied to the various components in the system. A BC 2.71L stroker kit will yield higher forces than a standad 2.5L engine at any given RPM due primarily to three factors.
1. Extended stroke. A longer stroke means that the average piston speeds (and by definition average loading) will go up at any given RPM. 2. the extra stroke alters your rod stroke ratio, increasing the rate of acceleration the rod/piston see. 3. the 2.71L displacement is arrived at via an 83mm stroke and 102mm bore. Generally going from a 102mm piston from a 99.5mm piston will add some weight, further increasing rod/bearing etc loading at a given RPM.
MartinSTi05 is offline   Reply With Quote
Old 07-14-2008, 09:34 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
Sorry, I did not mean to come off as agressive but rather wanted to straigthen out the facts. Also, my wrist pin is not in my ring lands...I just chose my components wisely
same reason it is easy to assembly my long rod setup...others it would depend on how they did things.
Sounds like you are following in a similar path to mine
Old 07-14-2008, 09:38 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
also might add increased friction and decreased ring life
Old 07-14-2008, 10:18 PM   #20
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Its all good, just wanted to be clear And I have been mistaken before and will be again for sure. LoL
Old 07-15-2008, 11:55 AM   #21
MS WRX
Member#: 117780
2004 WRX
Sinster, i was not flamin ya dude, just made that face to show what a chevy sbc would look like at 8500 LOL
Old 07-15-2008, 11:04 PM   #22
MartinSTi05
Member#: 145145
2006 wrx STi
Another thing to consider regarding high RPM stroker operation.
Harmonics. Considering the fact that the 83mm Stroker crank uses oem bearing journals, by definition you have 1.5mm less overlap of the rod journal/main journal cross section as compared to a standard 79mm ej25/7 crank, and 4mm less overlap than an ej20/7 based setup. Material choices aside, this would make a crank that is less torsionally rigid. Losing rigidity generally accompanies a reduction in resonant frequency. Theoretically this would lower the RPM at which potentially damaging torsional vibrations can manifest themselves.
How much the above is really worth worrying about is still up in the air. I have a 2.71L crower kit now, and hope to get it running soon, i will let you guys know how it fares.
Last edited by MartinSTi05; 07-16-2008 at 08:33 AM. Reason: Homemade WRX caught a screwup;-)
Old 07-16-2008, 12:40 AM   #23
Homemade WRX
Member#: 33782
96 bastard child
also to add to the cons of the 2.7L is the clearancing of the block for the kit...so adding more loading on the block, increased harmonics and a weakened block...I'd say they start to run into issues at in the high-7k to low-8k rpm range
also you had a typo martin...the EJ25 is 79mm
Old 07-16-2008, 08:07 AM   #24
MartinSTi05
Member#: 145145
2006 wrx STi
Oops, my bad, your right, i was thinking ej20.
Old 08-25-2008, 03:18 AM   #25
PENGUIN_JF1BJ_EJ22T
Member#: 187550
2011 GR8
Obsidian Black Pearl
Default con rod clearance
Is anyone else having clearance issues when they are putting this motor together?
Last week I got back the block and started the rebuild, but when I finished connecting the first 2 pistons I found there was “knock” and an obvious metal on metal drag when I turned the engine over. Aver some careful inspecting and the help of a sharpie I found one of my con rods was hitting the block at BDC.
For this kind cash I thought it should be a no mod’in rebuild,
Going at a re-sleeved sti block with the dremel, That just seems wrong
PENGUIN_JF1BJ_EJ22T is offline   Reply With Quote
Brian Crower 83mm billet stroker crankshaft mikeesingh Engine/Power/Exhaust 1 05-31-2010 01:56 PM
injectors for a 2.71 stroker... help! greekmafia Built Motor Discussion 3 09-05-2008 11:32 PM
Brian Crower Cams, Springs, Stroker kits! WE GO THEM! RallySport Direct Engine/Power/Exhaust 1 07-10-2008 04:57 PM
Brian Crower 2.29L Stroker Kit : Subaru WRX EJ20 ElCuRaNdEr Built Motor Discussion 9 10-13-2007 11:12 AM
Brian Crower 2.29L Stroker Kit: Subaru WRX EJ20 ElCuRaNdEr Newbies & FAQs 3 07-24-2007 12:39 PM
