Old 07-08-2008, 06:51 AM   #1
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Question 18x8.5 44 offset
What size summer tires do you recommend on my bugeye?
I was thinking 245/35/18?
Unless there's a wide 235 tire that I can put on. I just don't want that stretched look. I'm lowered on PSS9's currently with rear camber bolts.
I'm assuming I'll have to roll my rears regardless of 235/40 or 245/35?
Magnum626 is offline   Reply With Quote
Old 07-08-2008, 08:18 AM   #2
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
235 40 18 should fit fine, try the azenis tire as they tend to run a bit bigger, i ran a 235 40 18 and on my 18x8.5 rgii advan +48's and didn't rub at all and i didn't have my fenders rolled, a +44 shouldn't rub unless you're super low.
ray101381 is offline   Reply With Quote
Old 07-08-2008, 10:20 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
255/35/18 :d
edit: why did my turn into :d?
Old 07-08-2008, 11:17 AM   #4
Magnum626
Member#: 62856
MBP SQC#197
Thannks for the quick responses.
How are the sidewalls on the 615s? I'm used to the stiffness of the re070 on my 17s. I was also looking at the RS2 and KDW also.
Oh and about the 255's....how heavy is the tire at that point? I'm not a big auto-x person but I wanna try to get some days on the little road course they have at E town.
Old 07-08-2008, 11:44 AM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
tirerack shows that the bfg kdw2 in 255/35/18 weigh about 26lbs a piece.
245/40/17 weigh 25lbs and 255/40/17 weigh 27lbs.
i believe the rt615s have a stiffer sidewall than the rs2s. i currently have kdw2s but i can't compare them to the re070s since i went from 225/45/17 to 255/35/18. re070s probably compare better to rt615s in sidewall stiffness while kdw2s are more like the rs2s, but re070s/rt615s/rs2s probably have far more grip than the kdw2s.
Old 07-08-2008, 11:53 AM   #6
Badler
Member#: 133597
The 615s are similar in sidewall stiffness to 070s. I have 18 x 8.5 +45 w/245/40 615s on Pinks and I had to have the rears trimmed to prevent rubbing. You will have to roll for sure.
edit: saw it was a WRX.
Badler is offline   Reply With Quote
Old 07-08-2008, 06:13 PM   #7
Magnum626
Member#: 62856
MBP SQC#197
Anyone have pics of the 615's 235's on an 8.5 wide wheel on a wrx? I just wanna make sure it doesnt look stretched.
Will I need to roll then? I'm sure I'll have to on a 245 with the 44 offset. I shouldn't have a problem with the fender lining though on a 245/35 right?
Old 07-08-2008, 06:55 PM   #8
Badler
Member#: 133597
I'm pretty sure you will still need to roll or add lots of camber. Lining should be fine. It wont look stretched, 615s are already on the wider side. ie: 235 615s are as wide as some 245s.
Old 07-09-2008, 01:49 AM   #9
Magnum626
Member#: 62856
MBP SQC#197
Awesome thanks man. RT615 in 235/40/18 it is.
Old 07-11-2008, 02:39 AM   #10
Magnum626
Member#: 62856
MBP SQC#197
Any other wide 235's out there? Grippy summers?
Old 07-11-2008, 09:06 AM   #11
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
235/40/18 Azenis RT615 on 18x8.5
as u can see, the RT615 is somewhat stretched on the 18x8.5. the 235's Advan Neovas i have now have absolutely no stretch on the same 18x8.5. if u dont mind spending money i'd look into the Nevoas and Toyo R1R.
ommmjido is offline   Reply With Quote
Old 07-11-2008, 09:35 AM   #12
Magnum626
Member#: 62856
MBP SQC#197
Yea, it does look stretched.
You didn't roll the fenders all the way around?
Any other online tire places besides tirerack, vulcantire, discountire, edge racing?
I might as well go 245/35/18. For the prices of the advans or R1R's I could get a set of winter wheels and tires...lol You lucky non winter state people....
Old 07-11-2008, 10:09 AM   #13
nhat
Member#: 140163
03 STi
hellaflunctional
www.citytireonline.com <- nasioc vendor
Old 07-12-2008, 09:51 AM   #14
Magnum626
Member#: 62856
MBP SQC#197
^Ahh forgot about them. Thanks nhat.
Would 245/40/18 be too tall and require more than just rolling? Also, at 255/35/18 you think I'd need to pull the fender? I don't ride my car slammed.
The 40 height would make me feel more comfortable driving in NYC.
Thanks again
Old 07-12-2008, 04:45 PM   #15
nhat
Member#: 140163
03 STi
hellaflunctional
255/35/18 on my car only required a mild fender roll in the rear with rce yellows.
245/40/18 would require me to get rear camber bolts and a more extreme roll to fit.
Old 07-14-2008, 09:01 PM   #16
ewrobes17
Member#: 131448
'05 Rollin on Volks
With BC Racing coilovers
If you aren't dropped too low, 255/35/18 will fit just fine with no rubbing issues. Although I do rock BC Racing coils so that makes a bit of extra room.
- Eric
ewrobes17 is offline   Reply With Quote
Old 07-15-2008, 02:06 AM   #17
Magnum626
Member#: 62856
MBP SQC#197
^What's considered too low?
I'm on PSS9's. This is what my car looks like on 17x7.5 50 offset wheels with 5mm spacers and extended studs.
Tires are RE070 takeoffs in 225/45/17.
Old 07-15-2008, 03:08 PM   #18
umscooby
Member#: 50902
05 STi
What offset are those?
umscooby is offline   Reply With Quote
Old 07-15-2008, 03:45 PM   #19
ommmjido
Member#: 35746
08 White GRB
^^^ +45
Old 08-02-2008, 08:08 AM   #20
Magnum626
Member#: 62856
MBP SQC#197
I might be able to get a great deal on Dunlop Direzza Z1 in 245/40/18 but I wonder if it'll look too tall.
Anyone have pics of 245/40/18?
Also anyone know the contact patch of the Z1 in 235/40/18? If it's wide enough I might get that instead.
Old 08-03-2008, 04:33 PM   #21
nhat
Member#: 140163
03 STi
hellaflunctional
i'm on rce yellows with stock struts and 255/35/18s fit just fine with a +48 offset. no rear camber bolts but i did have to roll the rear fenders.
i think you're safe with a +44 and 255s
Old 08-03-2008, 09:31 PM   #22
Magnum626
Member#: 62856
MBP SQC#197
LOL, yea I was afraid you'd say that. I don't like my selection of 245/35 tires.
So from the pic I should be fine just a bit of rear fender roll to be sure I suppose.
Tires are freaking expensive.
Old 08-23-2008, 07:57 PM   #23
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Has anyone else experienced a 255/35 on a 18x8.5 wheel +48? Im trying to select tires for my 07 wrx! I have RCE yellows, AGX struts and 29mm fsb.
Dubstar112 is offline   Reply With Quote
Old 08-23-2008, 08:25 PM   #24
nhat
Member#: 140163
03 STi
hellaflunctional
what do you want to know?
Old 08-23-2008, 09:10 PM   #25
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Well thanks for answering my question in another thread! I think Im sold on the 255 movement.
FS: Advan RG2 18x8.5 45 offset & Rays RS-Zero 17x7.5 48 offset exige Wheels/Tires 10 07-14-2010 10:05 PM
VOLK CE28N 18x8.5 +44 5-100 TITANIUM SILVER $2800 shipped Kenji815 TXIC Private Classifieds 3 03-24-2010 03:53 PM
18x8.5 44+ offset on my wagon? hella_sti Tire & Wheel 0 12-29-2008 01:48 AM
NYC: Volk CE28N Bronze 18x8.5 44 Offset fobolous Wheels/Tires 5 02-26-2007 04:59 PM
