Old 07-08-2008, 01:54 PM   #1
1quikwagon
Member#: 163825
1996 Leg Wagon Turbo
Default Strange Problem....
I have a 1997 subaru impreza obs wagon 5 speed. It recently started doing some pretty weird things... first of all the blower motor just stopped working, as well as all of the brake lights. When bringing the brake pedal up the doors will unlock. I do not know that much about these types of things, but the main thing I think it is is maybe the fuse block is going bad. Can anyone give me any insite as to what is going on here, thanks ahead of time.
Brandon.
1quikwagon is offline   Reply With Quote
Old 07-08-2008, 11:13 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suggest you first remove the battery cables and clean then along with the battery posts.
The blower motor may be bad or the relay for it could be defective. For the brake pedal switch see if you have voltage getting to one of the leads. Check all the fuses under the dash and hood for any blown ones.
Strange problem Moop Newbies & FAQs 2 09-16-2002 09:24 PM
Very strange problem with i-Club Dougeefresh General Community 4 07-29-2002 05:01 AM
strange problem...need opinions couldnthinkaone Transmission (AT/MT) & Driveline 2 05-21-2002 03:48 PM
Help needed! strange problem KEVINL Normally Aspirated Powertrain 12 07-11-2001 05:26 PM
Strange problem hope you can help Spectre23 Normally Aspirated Powertrain 19 03-23-2001 09:46 AM
