Old 07-08-2008, 02:10 PM   #1
wittmer25
Member#: 102970
2004 STi gt30r
Default Your setup and ignition adv. @ peak torque and redline
I would like to see how much ignition advance others are running at peak torque and redline? I realize that everyone's engine will not have the same VE at every rpm. Post your mod's that affect your engine's air flow (turbo, cams, ported heads, valve size, compression ratio, headers, intake mani, intake diameter, boost pressure, fuel, etc...). I am curious to see how the big turbos with big cams and built engines with different than stock compression are running and what kind of timing advance is required at peak torque and redline (whatever it may be).
EDIT: I know there are a lot of variables to VE.
wittmer25 is offline   Reply With Quote
Old 07-08-2008, 02:51 PM   #2
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
Here they come...........
icslowmo is offline   Reply With Quote
Old 07-08-2008, 04:16 PM   #3
GeneralTJI
Member#: 152680
Homebuilt Rotated t3/t4... load of other mods, on a stock motor / heads
Around 13-14 at peak torque and around 26-27 at peak hp on an average day / temp
This is 6600ft elevation on E85 btw...
GeneralTJI is offline   Reply With Quote
Old 07-08-2008, 06:24 PM   #4
wittmer25
Member#: 102970
2004 STi gt30r
I don't need any smart a$$ remarks either. Only post if you have something relavent to the thread.
GeneralTJI: thanks for the post.
Old 07-10-2008, 11:56 AM   #5
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I was running 17.5 degrees at torque peak (288lbs) and 36 degrees at redline. Max power was 260. 21psi tapering to 15. That's on a 150,000+ mile TD04/2.0L running E85 at 830ft elevation. Stock internals, standard bolt-ons. My motor spun a bearing due to oiling and on teardown had no signs of det.
My new motor is going to be an 8.5-9.0 compression 2.5L with ported 2.0L heads, 272 cams, .5 over valves, stock location GT3071R turbo, and 3" intake/MAF/inlet. I'm interested to see what people put for similar setups.
bluescoobywagon is offline   Reply With Quote
Old 07-10-2008, 12:27 PM   #6
benw
Member#: 103320
1998 swapped
Forester L
that's a good amount of timing for a 2.0L! What was your fueling like?
benw is offline   Reply With Quote
Old 07-10-2008, 01:40 PM   #7
Dom'sGurl
Member#: 150837
2006 Legacy GT
13 is always the answer
Dom'sGurl is offline   Reply With Quote
Old 07-10-2008, 02:01 PM   #8
dmross
Member#: 2818
2000 2.5RS
2.5l, large port EJ207 heads with oversized valves and Kelford 272 cams, 8.75:1 comp.
Running 15-16deg at peak TQ and 21-22deg at redline, 93 octane, 25->22psi on a GT30R.
dmross is offline   Reply With Quote
Old 07-10-2008, 02:01 PM   #9
wittmer25
Member#: 102970
2004 STi gt30r
Currently,
I have between 8.9:1 and 9.0:1 compression, 100mm wiseco pistons, +2mm "long rod" ratio, ported heads, stock size valves, el perrin header, cosworth cams 278/274, stock exhaust valves, supertech intake valves, 3" Diameter Intake, 2.5" IC piping, tvg deletes, stock TB, GT3076R .82 hotside, 3" TBE, stock intake manifold.
Running 24 psi boost from 4200 to 7000, 93 oct, 13-14 degrees at 4200 to about 19-21 degrees at 7000 rpm.
edit: ej257
Old 07-10-2008, 02:18 PM   #10
bluescoobywagon
Member#: 14911
Not A Wagon!
Ummm...
Code:
        0.38	0.97	1.11	1.35	1.46	1.58	1.78	1.98	2.12	2.25	2.38	2.45	2.60	2.75	3.00
800	14.70	14.70	14.70	14.70	14.70	14.70	14.70	14.70	14.70	14.70	14.70	14.70	14.70	14.70	14.70
1200	14.70	14.70	14.59	14.36	14.36	14.36	14.36	14.36	14.36	14.36	14.36	14.36	14.36	14.36	14.36
1600	14.70	14.70	14.70	14.36	14.25	14.15	14.15	14.15	14.15	14.15	14.15	14.15	14.15	14.15	14.15
2000	14.70	14.70	14.70	14.36	14.15	14.15	14.15	13.94	13.94	13.94	13.94	13.94	13.94	13.94	13.94
2400	14.70	14.70	14.70	14.47	14.36	13.94	13.94	13.84	13.73	13.63	13.54	13.44	13.25	12.98	12.89
2800	14.70	14.70	14.70	14.36	14.04	13.94	13.63	13.25	13.07	12.89	12.89	12.89	12.89	12.71	12.46
3200	14.70	14.70	14.70	14.36	14.04	13.94	13.44	12.89	12.71	12.46	12.38	12.30	12.30	12.22	12.06
3600	14.70	14.70	14.70	14.36	14.04	13.94	13.44	12.71	12.46	12.30	12.22	12.22	12.22	12.06	11.98
4000	14.70	14.70	14.70	14.47	14.25	14.15	13.25	12.71	12.38	12.22	12.14	12.14	12.14	12.06	11.98
4400	14.70	14.70	14.70	14.59	14.36	14.15	13.25	12.71	12.38	12.22	12.14	12.06	12.06	11.98	11.91
4800	14.70	14.70	14.70	14.59	14.36	14.15	13.25	12.71	12.38	12.22	12.14	12.06	11.98	11.98	11.91
5200	14.70	14.70	14.70	14.47	14.36	14.15	13.25	12.71	12.38	12.22	12.14	12.06	11.98	11.98	11.91
5600	14.70	14.70	14.59	14.36	14.25	14.04	13.16	12.54	12.38	12.14	12.06	11.98	11.98	11.98	11.91
6000	14.70	14.59	14.36	13.84	13.54	13.34	12.54	12.46	12.38	12.22	12.14	12.06	11.98	11.98	11.91
6400	14.36	14.04	13.25	12.80	12.71	12.46	12.46	12.38	12.22	12.14	12.06	11.98	11.91	11.83	11.69
6800	13.84	13.07	12.80	12.63	12.46	12.38	12.30	12.14	12.06	12.06	11.98	11.91	11.83	11.69	11.61
Old 07-10-2008, 02:25 PM   #11
bluescoobywagon
Member#: 14911
Not A Wagon!
Actually I think it was 12...
Old 07-10-2008, 03:30 PM   #12
benw
Member#: 103320
1998 swapped
Forester L
Ummm...
I just meant what AFR you were running. E85 curiosity mostly!
Old 07-10-2008, 04:38 PM   #13
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
13 and 30!
SloRice is offline   Reply With Quote
Old 07-10-2008, 05:06 PM   #14
bluescoobywagon
Member#: 14911
Not A Wagon!
I knew that. It's pretty much 12:1 at full load and leaning towards 12.5:1 at redline.
Old 07-11-2008, 04:47 PM   #15
charliew
Member#: 125304
Originally Posted by wittmer25 View Post
Currently,
edit: ej257
wittmer 25 has acvs intake also (04 sti originally)
also I don't think he has had any detonation events to date
charliew is offline   Reply With Quote
Old 07-11-2008, 07:40 PM   #16
pddvl1
Member#: 134480
02 wrx
blue
till it detonates or knocks then back it off use your logging software
pddvl1 is offline   Reply With Quote
