Old 07-08-2008, 06:46 PM   #1
willy_fresh10
Member#: 73448
2004 wrx
JBP ej207 18G'd
Default Pulling engine and stuck.
I'm in the process of pulling my engine and all I have left is to seperate the engine from the transmission. What I cant figure out is how to remove the pin in the transmission that hold the clutch fork in place. I removed the cover with the 10mm hex but what do I use to remove the pin. I heard a battery tie down works but I don't have one. Please help.
willy_fresh10 is offline   Reply With Quote
Old 07-08-2008, 06:56 PM   #2
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
take any of your 10mm head bolts (i.e- the one for the grounding wire that connects to the tranny, screw it in and it pulls right out...like butter
Benchmark Tuning is offline   Reply With Quote
Old 07-08-2008, 11:46 PM   #3
willy_fresh10
Member#: 73448
2004 wrx
JBP ej207 18G'd
Thanks got it out and good to go.
Stuck plugs - dealer wants to pull engine? rupertberr Service & Maintenance 53 05-14-2009 07:37 AM
Have you pulled the engine and tranny on a WRX or STi? Samurai_jim Newbies & FAQs 9 12-03-2008 08:54 AM
pull engine and tranny together or seperate? felixwankel88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-29-2008 12:30 AM
Need '04 + STi engine assembly willing to Pull myself and pick up ej25subie Private 'Wanted' Classifieds 0 04-14-2007 10:10 PM
Pulling the engine and heads out and doing some major work. powerlabs Normally Aspirated Powertrain 5 04-27-2005 12:25 PM
