Old 07-08-2008, 11:55 PM   #1
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Default 2.0 heads on sti block
Im going to be putting 2.0 heads on a sti block but was wondering what gasket kit i would need to use for this. Would it be a 2.5 or 2.0?
crpwrx is offline   Reply With Quote
Old 07-10-2008, 04:14 PM   #2
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Yeah...I'd like to know too!
PSolbergfan is offline   Reply With Quote
Old 07-10-2008, 08:26 PM   #3
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Well im guessing i would have to use a 2.5 gasket kit for the motor and maybe use 2.0 head gaskets. Anyone?
Old 07-11-2008, 12:12 PM   #4
doug*E*fresh
Member#: 116794
02 wrx
sedona red
i think alot of people use cometic headgaskets designed for this. That is what mine has. I did not do the swap so cant give you a 100 percent for sure answer.
doug*E*fresh is offline   Reply With Quote
Old 07-11-2008, 07:24 PM   #5
25rsti
Member#: 166324
i just came from the subaru dealership and they have the sti kits under 3 different part numbers. id like to know which to get too.
Old 07-11-2008, 07:47 PM   #6
javastiwagon24
Member#: 144372
0407 STIwag & 01 STI
Rotated!Widebodied!RaLLY
you can choose which one you want. Believe me you will want the higher compression if you don't plan on running 25+lbs of boost. I got mine from cometic they have a 2.5l 60thousandths gasket, the of boost response was great and on boost was even better. I was pushing 22lbs to about 5k tapering to 14lbs at red. I believe the non turbo 2.5rs gasket is the same thickness so that would be a good place to start. Dont forget copper gasket spray. by the way, 2.6l with wrx heads "stock ones." td04 20+lbs before 2500rpm.
Can anybody say torque. WOW. but wasn't worth going past 5750rpms. better to just shift. Hope this helped.
ps make sure you trough the stock pistons in the garbage.
javastiwagon24 is offline   Reply With Quote
Old 07-11-2008, 07:47 PM   #7
javastiwagon24
Member#: 144372
call weisco or use a compression calculator. that will tell you what the end result will be.
Old 07-12-2008, 01:07 AM   #8
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
^^+1 nice pulling ride IMO
sense of nature is offline   Reply With Quote
Old 09-28-2008, 08:55 PM   #9
tripleAAA/RRR
Member#: 190423
2002 wrx
blue
you will need 2.5l headgasket ! dont by the full kit by the peices you wont us all the parts
tripleAAA/RRR is offline   Reply With Quote
STI cams in 2.0 heads on 2.0 block? OUScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-06-2010 11:05 PM
2.0 heads on a 2.5 block- what else? thewerxracing Newbies & FAQs 7 10-22-2009 01:34 PM
WRX 2.0 heads on STi bottom end... Compression? jblackwell Subaru Conversions 2 10-23-2008 09:33 PM
WRX 2.0 heads on STi bottom end... Compression? jblackwell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-07-2008 12:53 PM
USDM 2.0 heads on a USDM STi Block? NicktheBrit Built Motor Discussion 5 03-06-2008 05:11 PM
