Old 03-05-2002, 03:18 PM   #1
thng
Member#: 8062
Default EJ20 NA motor?
Has anyone anywhere ever seen or heard of am ej20 motor used in an NA application?
I just had an imagineering bout and figured I'd try to treat it before I start running a temp...
Ted
thng is offline   Reply With Quote
Old 03-05-2002, 03:22 PM   #2
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
The syms JTCC uses an NA motor.
illmatic is offline   Reply With Quote
Old 03-05-2002, 04:33 PM   #3
Cacophony
Member#: 213
2004 Mazda RX-8
I'll have to dig out my HyperRev to be sure.. but I think that NA Syms racing wagon puts out around 390hp as well. I believe it had all sorts of trick stuff like individual throttle bodies, etc.. Quality stuff
Cacophony is offline   Reply With Quote
Old 03-05-2002, 09:09 PM   #4
thng
Member#: 8062
Okay, so now there is a series of parts available, made by subaru, for the ej20....higher compression pistons, camshafts, etc, etc....
Wait! What kind of heads? Does anyone know what the chamber displacement is on the usdm wrx? And, if jtcc uses the same heads or different?
Now I gotta find some part numbers, cost, and so on.
Old 03-05-2002, 09:24 PM   #5
illmatic
Member#: 3536
Here!
Old 03-05-2002, 10:21 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Currently, in Japan, Subaru sells an Impreza model called the WRX NA, with a 2L DOHC 16V AVCS engine rated at about 153HP.
http://www.subaru.co.jp/impreza/wrx/...ism/index.html
Jon [in CT] is offline   Reply With Quote
Old 03-07-2002, 12:43 PM   #7
worry
Member#: 13461
Hyperrev impreza isue 2 shows the Syms JTCC car. It runs 290PS, not 390PS, according to that issue of hyperrev. 290PS from a N.A. 2 litre engine is pretty good anyway. Most of the BTCC cars over here manage around the 300bhp mark too.
worry
bbs.22b.com
worry is offline   Reply With Quote
JDM & USDM NA motor specs go go go Normally Aspirated Powertrain 27 07-12-2008 03:47 PM
what does the sti mean to 2.5 NA motor owners? liigod STi Forum Archive 17 01-07-2003 07:53 AM
need a 2.2 NA motor kenrmutch Canada Region Forum 2 11-18-2002 02:45 PM
2.2 NA motor & tires kenrmutch Vancouver Impreza Club Forum -- VIC 5 11-16-2002 10:42 PM
anyone got the specs on the ej20 NA? mcu81 Normally Aspirated Powertrain 4 06-30-2002 05:05 AM
