Old 07-08-2008, 11:17 PM   #1
mchrenen
Member#: 72427
03 WRX MBP - sold!
07 FXT Sports UGM FTW
Question things that are NOT working on my WRX
1) passenger side EDM headlight. Just replaced the H1 bulbs and then tried the associated fuses, no luck. The drl still works though.
2) cruise control
3) horn
are these things related or am I just having bad luck Any suggestions? thanks
mchrenen is offline   Reply With Quote
Old 07-09-2008, 10:26 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suggest you order the factory service manual that covers the wiring for the car. You will more than pay for the cost of it by using it to help you fix just these problems.
Cougar4 is online now   Reply With Quote
Old 07-11-2008, 02:48 PM   #3
Jeenyus
Member#: 152911
04 wrx
I date men
my car is being weird too... my fuses are fine, switched the bulbs, and still no rear day lights.
Jeenyus is offline   Reply With Quote
Old 07-11-2008, 05:02 PM   #4
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
cruise control/horn probably means the 'rotor' in your steering wheel is busted. I recently had the same problem and just replaced it with a sparco steering wheel....LOL. I still need to re-wire the horn and CC, but the 'rotor' is very expensive from the dealer. I've been told $300.
for those of you with headlight issues, did you check the relays? engine bay fuse box has the headlight relays.
UP2MTNS is offline   Reply With Quote
Old 07-16-2008, 12:31 AM   #5
mchrenen
Member#: 72427
03 WRX MBP - sold!
turned out to be just a pinched wire for the headlight plus some corroded connections, got em cleaned up and regreased everything works
took it to DS1, guess they do everything there
A/C is not working on '04 WRX mattswrxnc Factory 2.0L Turbo Powertrain 12 08-28-2012 10:49 AM
Gauges not working on 02 WRX jjs316 Factory 2.0L Turbo Powertrain 6 06-30-2008 05:02 PM
For those of you that are not working today Matt_H Mid Atlantic Impreza Club -- MAIC 19 12-23-2006 07:07 PM
OT: Some pictures of what I work on when I am not working on my RS. paultg New England Impreza Club Forum -- NESIC 15 07-06-2001 05:48 AM
Attn. Chad, Kris and all that are helping work on my car. bill harvey New England Impreza Club Forum -- NESIC 2 07-20-2000 06:35 PM
Message Board Statistics All times are GMT -4. The time now is 05:51 PM.
