Old 07-09-2008, 01:15 AM   #1
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Default Rare gauge mounting pod---where can I find one?
Hey I've done my research...evidently this isn't the popular place to mount gauges.
Does anyone know where I can get one of these?
I want to mount three 52mm gauges right beneath my head unit. I still haven't found someone who sells one.
Nate
lennyTR is offline   Reply With Quote
Old 07-09-2008, 01:34 AM   #2
spin'nall4
Member#: 135322
2004 Subaru Sti
Aspen white
http://egauges.com/vdo_acce.asp?Subg...c_DIN&Manf=All
you will just have to figure a way to mount the panel.
spin'nall4 is offline   Reply With Quote
Old 07-09-2008, 01:37 AM   #3
spin'nall4
Member#: 135322
2004 Subaru Sti
Aspen white
also
http://www.j-spectuning.com/product_...products_id/67
this one comes with the mounting rails and little visors
and
http://www.j-spectuning.com/product_...products_id/66
omori gauges are really nice too btw. i have j-spec tunings 60mm any color gauges in their cf dash top pod.
if you cant mount the ones that are just panels then you can probably just cut the mounting rails off of a stock subaru blank or pocket and glue the new panel to the rails.
Old 07-09-2008, 02:15 AM   #4
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Awesome. Thanks guys. Exactly what I was looking for. I knew somebody out there made one.
Old 07-09-2008, 07:28 AM   #5
SloBug
Member#: 183542
2001 Bug Eye
just be carelful with ones that arent made for the wrx. i tried to use the angled one in my bug but it wouldnt fit in the space and the gauges on the angle hit the head unit mounting brackets.
i fit mine in with a bit of cutting and an aluminium bracket bolted to the head unit bracket but i dont think the above DIN sized facias will fit. double check before you buy them if you can...
mine fit in like this after a lot of swearing...
SloBug is offline   Reply With Quote
Old 07-09-2008, 12:51 PM   #6
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Are those 60mm gauges?
Old 07-09-2008, 07:17 PM   #7
SloBug
Member#: 183542
2001 Bug Eye
52mm, and they are slightly cut off at the top. you can see all the gauge, just not all of the surround...
Old 07-09-2008, 11:38 PM   #8
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Hmm. Well I still really want to mount mine below the radio...hopefully mine will fit so that they can be seen clearly.
Old 07-16-2008, 12:16 AM   #9
spin'nall4
Member#: 135322
2004 Subaru Sti
Aspen white
test fit the gauges in the opening first. the subaru has a double din opening so they should fit if they are 52mm gauges. those gauges in slobug's car look alot like 60mm's or just 52's with really big trim rings.
Old 07-16-2008, 05:46 AM   #10
akinasdevil
Member#: 61050
2004 STi
72 Corona
I want to do the same thing with my 52mm gauges. I PM'ed J-spec and they don't have anymore of the Omori pieces, they sold out last month and aren't expecting anymore as the piece is discontinued.
akinasdevil is offline   Reply With Quote
Black Subaru badge... where can I find one? snvin Interior & Exterior Modification 7 06-14-2004 12:57 PM
Big Rear Sway Bar for BD Legacy? Where can I find one? JSiwek Legacy Forum 17 12-20-2003 01:02 AM
"T" for autometer boost gauge, where can i find one RossWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-26-2003 02:10 PM
steering rack..where can i find one ScoobyJoe Brakes, Steering & Suspension 3 08-24-2002 12:14 AM
('93-'01) Subaru wear? where can i find one Lightning Jack Impreza Forum 4 10-21-2001 03:49 AM
