Old 07-09-2008, 10:52 AM   #1
attitude
Member#: 52043
04 sti
Default cyl/piston clearance with anti friction coating
should it be any different with a swaintech coating than is recommended in the manual?
attitude is offline   Reply With Quote
Old 07-09-2008, 12:03 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
IMO you want to set it to the original size of the piston and not to the coating. This assumes that the coating will wear off, which it does.
mick_the_ginge is offline   Reply With Quote
Old 07-09-2008, 12:05 PM   #3
attitude
Member#: 52043
04 sti
thank you, thats what i thought
JE - 100mm, 8.5:1 compression pistons with wrist pins - coated brand new awd4ever 1993 - 2001 Impreza Specific Parts 5 05-30-2010 12:07 PM
JE - 100mm, 8.5:1 compression pistons with wrist pins - coated.(Brand new) awd4ever Engine/Power/Exhaust 3 04-04-2010 06:38 PM
JE - 100mm, 8.5:1 compression pistons with wrist pins - coated.(Brand new) awd4ever NWIC Private Classifieds 4 04-04-2010 06:38 PM
Wiseco Pistons .020 Over bore w/ friction coating [email protected] Engine/Power/Exhaust 4 10-11-2008 04:25 AM
Lubro Moly Anti Friction MOS2 bwco Transmission (AT/MT) & Driveline 5 11-15-2005 12:51 AM
