Old 07-09-2008, 12:21 AM   #1
imprezaL2345
Member#: 108188
1993 Impreza L 1.8T
Lotus Storm Titanium
Default torque specs for ARP studs. question.
i was planning on using the torque specs from my chiltons manual to tighten the bolts down until i read this:
which says to torque them down to 72lbs instead of the 1 & 2 to 17lbs and so on. so the question: which should i do.
imprezaL2345 is offline   Reply With Quote
Old 07-09-2008, 01:07 AM   #2
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Follow ARP's guidelines. If you use the factory sequence, you will strip a nut, stud, or the threads in the case.
Also when you torque to the final number, I recommend doing it in 3-4 steps (Such do them all to 20, then all to 40, then all to 60, then all to 72)
wrx_driver_2002 is offline   Reply With Quote
Old 07-09-2008, 01:47 AM   #3
Rickyh
Member#: 40453
Read this.
It has a detailed discussion about arp studs, oem bolts and different methods used to torque both of em down.
Rickyh is online now   Reply With Quote
Old 07-09-2008, 11:13 AM   #4
imprezaL2345
Member#: 108188
1993 Impreza L 1.8T
so going off of the\is:
Originally Posted by bugeyes View Post
Finally had to an aswer from ARP on the stud kit. Here is the content of the email I got back-
"KIT # 260-4701 HAS 11MM STUDS IN IT. SO THE TORQUE WITH ARP MOLY LUBE
WILL BE 80 FT LBS. DO THIS IN 3 EQUAL STEPS, YOU WANT THE FINAL TO BE AT
LEAST 25 TO 30 FT LBS OF TORQUE. YOU DO NOT USE ANY TORQUE ANGLE WITH
OUR FASTENERS. IF YOU ADD AN EXTRA 90 DEG TORQUE TO THE STUD AFTER TORQUING IT TO 85 FT LBS YOU WILL MOST LIKELY FAIL THE FASTENER.
NOW THE STUDS WILL GO IN THE BLOCK HAND TIGHT ONLY NO MORE THAN 1 OR 2
FT LBS OF TORQUE. IF THEY GO INTO WATER YOU NEED TO USE A THREAD SEALER,
IF DRY HOLES THEN USE THE MOLY.
WITH A NEW STUD YOU NEED TO RUN IT THRU THE TORQUE CYCLE 3 TIMES TO
BREAK THE THREADS IN. WITH THE 4th TIME THE FINAL TORQUE.
THE KIT YOU HAVE IS A HIGHER GRADE MATERIAL THAN OUR REGULAR STUDS. REGULAR
STUD = 200,000 PSI KIT # 260-4701 = 220,000 PSI.
i should torque the studs in 4 steps(20,40,60,72) in subaru sequence, then loosen, and retighten them, 3 more times?
Old 07-09-2008, 12:20 PM   #5
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
Yes you must tighten them and loosen them a total of 4 times. That is the correct way to Tighten ARP's. If you do not you will more than likely have a hg failure.
Josh
Whiteghost 2.5 is offline   Reply With Quote
ARP stud question jaironsti Built Motor Discussion 1 12-10-2009 02:47 AM
Torque specs for Cosworth rod bolts for EJ25? Navid Built Motor Discussion 0 10-20-2007 10:57 PM
Official Head Bolt/Stud Torque Specs for Various Motors White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 20 06-17-2006 06:42 PM
looking for torque specs for valve cover, spark plugs and coil packs Tobey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-13-2005 03:35 PM
Torque specs for pulley? JGard Normally Aspirated Powertrain 9 04-12-2001 10:01 AM
