Old 07-09-2008, 10:54 AM   #1
Rudywrx04
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
Default Is 280 WHP possible on stock turbo 2.0
Here is a list of my current mods;
3 inch catback exhaust, Catted down pipe, uppipe
Turbo XS top mount , AEM cold air intake , crank pulley
1 step colder plugs, Pink injectors, walbro Fuel Pump
Ported throttle body mod, grounding mod.
Pro tuned on UTEC and curently at 248 whp on a dynojet.
I do not want to change turbos. I want to have a very quick spool setup.
If I added a P&P stock turbo, and grimmspeed mainifold and crossover, Perrin turbo inlet. Would this get me 270 whp? Would meth injection get me to my goals? I know you can not make any promises, but just wanted to see if these mods would get me close to my goals.
Rudywrx04 is offline   Reply With Quote
Old 07-09-2008, 10:57 AM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Even with meth injection, it's unlikely that you'll make that much on a true dyno. How bout a small 16G? That'll get you there, with near-stock spool and much much better top-end. If you really wanna do it right, the Small 16g on meth
Audiosavvy is offline   Reply With Quote
Old 07-09-2008, 11:06 AM   #3
FreNetiC STi
Member#: 164797
It gets me from
point A-B
^^yup...and yup.
FreNetiC STi is offline   Reply With Quote
Old 07-09-2008, 11:09 AM   #4
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
yeh 16g + meth 4sho
mxpunk is offline   Reply With Quote
Old 07-09-2008, 11:16 AM   #5
wrxdrivr04
Member#: 156619
2004 WRX 2.5 hybrid
FP EVOIII 16g
Default Stock Turbo
Yea i have a 04 wrx with turbo back, megan racing header and uppipe, Short ram Intake, on stock turbo with a pro tune by ams in gaithersburg, md on 16psi and i put down 249AWHP, and 244 AWTQ and ran a 13.0 @ 104... Currently just put FP EVO III Big 16G with Supporting mods on... still have to getting it tuned will let you know what i put down.... as for 280 on stock turbo with 2.0l i dont think so possible 260 tops i would have to argee with everyone small 16 will get you there.
wrxdrivr04 is offline   Reply With Quote
Old 07-09-2008, 11:16 AM   #6
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
You can get to 300 whp on a stock turbo. Anything is possible. It's about the tune and how deep your pockets are.
Thug Nasty is offline   Reply With Quote
Old 07-09-2008, 11:43 AM   #7
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
^^ I would love to see a td04 get 300whp on our 2.0's but it would never happen....Maybe with a 50 shot it would haha
Cards2323 is offline   Reply With Quote
Old 07-09-2008, 12:18 PM   #8
FreNetiC STi
Member#: 164797
It gets me from
point A-B
no, it's about the tuner manipulation on the dyno. realistically, that TD04 is not hitting 300whp. ported and on meth, maybe, but what a waste.
Old 07-09-2008, 12:21 PM   #9
big16gwrx
Member#: 129459
not going to happen .....
big16gwrx is offline   Reply With Quote
Old 07-09-2008, 12:23 PM   #10
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
300 @ the crank is very possible..@ the wheels is a long shot
Old 07-09-2008, 01:25 PM   #11
clbd39
Member#: 104078
2002 SRP VF43 WRX
P&L Jorge Tuned
waste, just upgrade the turbo and get a good tune, it's really not that noticeable...
DO IT!
clbd39 is online now   Reply With Quote
Old 07-09-2008, 01:39 PM   #12
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You could get 300 on a stocker as I remember the day when people thought you couldn't break 12s on the stocker too. To do it you'd have to have every bolt on there is. Then you'd have to have 100% meth injection and you'd have to have an external wastegate. No one has been crazy enough to do this yet, so I say you be that crazy person.
<-----250 on my stocker now, but will finally go Super16G very soon
Old 07-09-2008, 02:50 PM   #13
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Very possible! Get a stroker kit and bore out to a 2.2L, EWG, Pink Injectors, Totally Catless, your cold air intake, Meth, your intercooler, and a really good tune
emsmap is offline   Reply With Quote
Old 07-09-2008, 03:47 PM   #14
GRUMPY514
Member#: 112285
2014 BMW 535i
Alpine White
td04= No 300whp.
Theres a thread going on right now about a guy asking what it would take to get 300whp on a stock 2.0L you should take a gander in there.
Ill see if I can find the link for you. You WILL need a turbo upgrade. No way around it bud. It will make things a LOT easier to just upgrade the turbo then to do every possible mod there is bolt on wise/PnP wise etc.
GRUMPY514 is offline   Reply With Quote
Old 07-09-2008, 03:51 PM   #15
GRUMPY514
Member#: 112285
2014 BMW 535i
Alpine White
http://forums.nasioc.com/forums/show....php?t=1551361
There you go, doing a turbo upgrade will be a lot cheaper to achieve 300whp then to do everything else BUT a turbo upgrade. You don't have to go huge, like unabomber said hes doing a 16g or you could also do an 18g upgrade.
Same exact situation except you got a little more flab with your vehicle being a wagon and all, hes also shooting for 20whp more.
Old 07-09-2008, 08:49 PM   #16
dmick1981
Member#: 163281
2003 bugeye cobbstg2
psm
Impreza WRX
i've been looking at getting a 16g, td05 or vf39/43
dmick1981 is offline   Reply With Quote
Old 07-09-2008, 08:52 PM   #17
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Depending how the dyno you are on reads, a 20G sometimes barely breaks 300whp.
That said, if you are at 248, you can easily hit 270 with a manifold/x-over and meth. Just run a BUNCH of boost. 22-23PSI range. Dont plan on the turbo lasting too terribly long at that kind of boost levels, but they are cheap and easy to swap. meth will be the key. If you are at 248 now, meth alone will get you to 270.
But you will be running the motor HARD. Just do a normal TD05-16G 7cm and call it a day.
Defiant Autospeed is offline   Reply With Quote
Old 07-09-2008, 09:29 PM   #18
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Originally Posted by Unabomber View Post
Super16G very soon
It's ok
fs: stock turbo, 2.0 stock injectors, rear diff...... gda03subaru TXIC Private Classifieds 12 06-10-2010 05:31 PM
VF36 possible on USDM WRX 2.0 engine? coldfire7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-19-2008 05:12 PM
Stock turbo 2.0, 250whp 290wtq on 93oct... Swine Proven Power Bragging 48 07-11-2008 07:48 PM
How/What is most power possible on stock turbo 06/7 wrx? confusedxpanda Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 40 08-09-2007 09:52 AM
[email protected] Stock Turbo 2.0 WRX OppositeLock Proven Power Bragging 82 03-09-2007 04:53 PM
