Old 07-09-2008, 11:46 AM   #1
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
Default Rubbing witth 17x8,5?
Hy!
I have 07 wrx sedan. I'm thinking to get advan rs 17x8,5 et48 wheels.
What tyres will be better - 235/45/17 or 235/40/17 and less rubbing?
Also I'm planning to lower my car with prodrive springs.
Looking for some advice guys!
Tomas
Tomas26 is offline   Reply With Quote
Old 07-09-2008, 12:01 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
You'd definitely be fine with 235/40-17, and most likely fine with 235/45-17. I think the 235/40-17 is closer to stock diameter.
Old 07-09-2008, 12:32 PM   #3
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
you'll be fine, i had 18x8.5 advan rgII's with a +48 and didn't rub, i ran azenis 235/40/18, i dind't have any fender modifications either
ray101381 is offline   Reply With Quote
Old 07-09-2008, 03:35 PM   #4
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
so what tyre size your recommend? 235/40/17? Would be nice not to have any rubbing issues, because i don't want to roll my fenders... i presume prodrive springs will not lower my car so much that any rubbing could appear.
Old 07-09-2008, 03:41 PM   #5
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
with a +48 i think you'd be ok running a 245/40 without rubbing, and that would be a really good tire size too. if you want to be really safe you could run the 235/45 or 235/40. i personally think the 245/40 would look the best and give you slightly better gearing as the 06-07 wrx's are geared really tall. i never tried a 245 tire on my setup but i'm pretty sure that i could've run that size tire without rubbing. maybe someone else can chime in. a +48 should give you enough fender clearance.
Old 07-10-2008, 06:36 AM   #6
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
Well, i have 4.11 FD not like you guys have 3.7 FD, because mine wrx is edm spec. That's why i don't want shorter gearing. To be really safe at first i want to try 235 wide tyres, and then if there will be enough clearance maybe i will go for 245. So as i understood you guys recommend 235/40/17 over 235/45/17?
Old 07-11-2008, 05:46 AM   #7
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
bump for answers...
Old 07-11-2008, 07:48 AM   #8
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
well with a 4.11 FD i'd get teh 235/45. a buddy of mine runs that size on his 17x8 rpf-1's and is really happy with them, i think they look really good on a 8 inch wheel too. i really do think you'll be ok with a 245/40 though. also go to tire rack and look at all the specs, some tires run a bit bigger than others and some 235 might be as big as a 245.
Old 07-11-2008, 09:10 AM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
and if you order from tirerack, click the banner ad at the top left.
luke hates it when we don't...
Old 07-11-2008, 11:36 AM   #10
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
i did some research and find out that 245/40 tyre size would be the best for 8,5 wide rim and closer to stock tyre size. I'm planning to take bridgestone potenza re050a tyres, are they big? I'm worried about rubbing issues with 245/40 though...
Old 07-11-2008, 11:50 AM   #11
nhat
Member#: 140163
03 STi
hellaflunctional
with those wheels, tire size, and springs, all you'll need to fix any rubbing is a mild rear fender roll.
Old 07-11-2008, 12:44 PM   #12
Tire Rack Moderator
Member#: 1215
ext. 4362
I know many people who run 245/40-17 and also 235/45-17 .... the 235 is slightly taller than stock and does have a little effect on the overall gearing. 245/40-17 is the more popular choice but, most people end up doing a little fender work
Old 07-11-2008, 01:31 PM   #13
Chris_Lee
Member#: 110667
2006 WRX
I'm running Falken 452's 245/40/17 on 17x8 Rota gForce. I forgot the offset though. I love this set up and I'm going to keep using the 245 width when I replace this set of tires. I wouldn't go with a 45 sidewall. It makes the sidewall look just to tall. A 40 sidewall looks better imho and doesn't throw your speedo off by more than 1 mph. My car is lowered and after the aglinment I had no rubbing issues.
Chris_Lee is offline   Reply With Quote
Old 07-11-2008, 03:44 PM   #14
nhat
Member#: 140163
03 STi
hellaflunctional
the 17x8 gforce is +48.
Old 07-12-2008, 05:05 AM   #15
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
you have 06 wrx sedan? i'm planning to get 17x8,5, so it's wider then 17x8... That's why i could get rubbing in the rear with 245/40/17...
Old 07-12-2008, 03:58 PM   #16
nhat
Member#: 140163
03 STi
hellaflunctional
a wider wheel isn't going to cause rubbing, low offsets and/or taller than stock tires do. fwiw, i have 18x8.5 +48 with 255/35/18s and i have no rubbing whatsoever.
with 245/40/17 on a 17x8.5 +48 wheel, the only thing you might need to do is roll your rear fenders. you could even go with 255/40/17 if you wanted to, but you would definitely need to roll the rear fenders for that.
Old 07-13-2008, 01:33 PM   #17
Chris_Lee
Member#: 110667
2006 WRX
As far as I know the 06 WRX won't accomadate 255 in the wheel wells with out modding. STi can use 255 without mods. As far as widths go 235 is plenty for the street but I prefer 245. If I could run 255 I would but for my driving situation it's not worth the effort or money. 245's do look good and they really fill out the wheel wells.
Old 07-13-2008, 02:58 PM   #18
nhat
Member#: 140163
03 STi
hellaflunctional
my 04 sti with rce yellows wouldn't fit 255s without rolling the fender . it didn't cost me much to have them rolled.
245/40/17 on 17x8.5 +48 rubbing ? STi_4_life Tire & Wheel 10 01-13-2009 02:12 PM
17x8.5 +48 and 245/40/17 - Possible rubbing? EdHilario Tire & Wheel 18 11-22-2008 02:29 PM
Wagon fender rub with 17x8.5 45 offset rims? alwrxwu Tire & Wheel 8 01-03-2007 02:30 PM
Any WRX lowered on 17x8.5 rims w/o rubbing or rolling fenders PinnacleChronos Tire & Wheel 2 05-07-2005 02:15 AM
STi w/ 17x8.5 & 255/40 -- rub? Luke? gregr01 Tire & Wheel 8 10-14-2004 03:58 PM
