Old 07-09-2008, 12:08 PM   #1
tbizzle
Member#: 145177
2000 Impreza
SRP
Default flow rate for Legacy injectors (2002 Legacy Injectors)
I bought these as 2.5RS injectors for my 2000 2.5RS, but figured I'd check the part numbers out before I installed them. Turns out they're injectors for a 2002 Legacy. I know my stock injectors flow 280cc, but it'd be great if I could use these as a replacement. otherwise they're up for sale...
tbizzle is offline   Reply With Quote
Old 07-09-2008, 09:26 PM   #2
rougeben83
Member#: 115154
2003 Legacy L Turbo
theyre replacements.
rougeben83 is offline   Reply With Quote
Old 07-10-2008, 01:37 PM   #3
tbizzle
Member#: 145177
2000 Impreza
SRP
you mean they're not original, or you mean i can use them? can anyone else confirm this? it'd be awesome if i could use them.
Old 07-10-2008, 04:01 PM   #4
rougeben83
Member#: 115154
2003 Legacy L Turbo
the 00 legacy uses the same phase 2 motor as your 2.5RS. If they're not exactly the same, theyre close enough for you to use them interchangeably.
What is the normal fuel flow rate for a 2000 Legacy using an EJ253 engine? steiny85 Newbies & FAQs 0 04-14-2008 04:59 PM
flow rates for ej25 Dawson Built Motor Discussion 0 09-10-2006 04:23 PM
Injector flow rates, power dips and other stuff hotrod Engine Management & Tuning 24 01-30-2003 02:05 AM
Sti Injector Flow Rate BB18T Factory 2.0L Turbo Powertrain 4 09-12-2002 04:30 PM
WRX Injector Flow Rate @ Idle Fuel Pressure HndaTch627 Factory 2.0L Turbo Powertrain 6 09-29-2001 01:21 AM
Message Board Statistics All times are GMT -4. The time now is 05:35 PM.
