Old 07-09-2008, 05:56 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default How much tire off-set is allowed on AWD car?
I have noticed recently that RR tire has about 1 - 1.5 /32" more tread compared to other 3 tires. I haven't noticed anything unusual in terms of drivability or handling-- I am fully aware that it is not an ideal situation for AWD drivetrain.
Any recommendation as to what I need to do aside from getting one used tire?
Thanks,
Old 07-09-2008, 07:14 PM   #2
illini_wrx
Member#: 155844
i think 1/16th is the threshold, so you're okay.
illini_wrx is offline   Reply With Quote
Old 07-09-2008, 08:02 PM   #3
fiveoh88
Member#: 125600
2005 STi perrin stg2
World Rally Blue
subaru is nuts...the tolerance they call for in all four tires is almost impossible to assure
something like a few psi difference in a tire can cause the tire to be out of tolerance...
theres been a bunch of threads on this with a split of people saying OMG don't run a tire with more than 1/32" difference tire tread than the others, and the rest saying that subarus tolerance in tire diameter is nuts and is almost impossible to do
fiveoh88 is offline   Reply With Quote
Old 07-09-2008, 08:52 PM   #4
Howl
Member#: 57830
Subaru recommends 1/8" circumference difference. Circumference is easier to measure than height or tread depth because the difference will be 3.14159 times larger. Jack up a corner and run a rope around the tire then measure the rope. Repeat for each corner.
Howl is online now   Reply With Quote
Old 07-09-2008, 11:44 PM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Just measured again across all 4 tires. Biggest difference is about 1.25/32" so I would think that I maybe okay. Not so sure though..
Old 07-10-2008, 09:06 AM   #6
Tire Rack Moderator
Member#: 1215
ext. 4362
I happen to run across this question quite often as people occassionally have to replace 1 tire. I have spoken with several people in the know when it comes to the Subaru AWD system and they say 3/32 - 4/32 is acceptable. On another note they also say that "the owners manual was written with to much influence from the legal department".
Old 07-10-2008, 09:36 AM   #7
xaznxeclipsex
Member#: 179310
2015 Forester XT
I have a theory: take out 1-3psi of air from the other 3 tires to compensate the 1 tire that has less thread. Wouldnt this even out the circumfrerence? And maybe even over time the other 3 tires with less air pressure will wear out a bit faster then the 1 tire with correct air pressure, when that happens just put all tires to the correct PSI.
Would my theory work?
xaznxeclipsex is offline   Reply With Quote
Old 07-10-2008, 12:52 PM   #8
Tire Rack Moderator
Member#: 1215
ext. 4362
theoretically it would but, any change in vehicle weight would alter the theory as it would cause a change in the static loaded radius
Old 07-10-2008, 03:21 PM   #9
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Actually, it wouldn't work.
The higher inflated tire would either wear more in the middle of the tread or remain unchanged, but the under-inflated tires are going to wear at the outside edges of the tread. Not to mention that just sounds like a bad idea in general.
To answer the OP, move that tire. Switch the backs L <-> R and see if it happens again to whatever tire is in that corner.
Ever check your alignment?
DiscoGsus is offline   Reply With Quote
Old 07-10-2008, 03:22 PM   #10
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
3-4/32 seems huge in tire wear difference... !
Old 07-10-2008, 10:21 PM   #11
Miroshnichenko
Member#: 182984
My family has owned 8 subarus that I can remember, many times they had different tires front/back... and most of the time they had different amount of tread left... we've NEVER had a problem, not even in the newer 05 Legacy 2.5i and 05 STi
..I think subaru exagerates.
Miroshnichenko is offline   Reply With Quote
Old 07-12-2008, 04:01 PM   #12
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Hope that really is true...
How Much Tire Run-out is Acceptable? Columbo Tire & Wheel 16 04-15-2010 12:17 PM
How much play or "lash" is normal on center differential? Clunk noticed. BBBsti LTD Transmission (AT/MT) & Driveline 8 05-21-2009 09:11 PM
on AWD car, if you get 2 flat tires you replace all 4, right? chu my pu Transmission (AT/MT) & Driveline 15 01-25-2007 09:35 AM
In NY, how did/do they do emissions testing on AWD cars? rice h8r Tri-State Area Forum 15 01-15-2006 07:48 PM
how much do you spend a month on your car? Remy E. LeBeau Off-Topic 43 10-10-2005 02:06 AM
